bb fox motor mounts
bb fox motor mounts Empty bb fox motor mounts
Post  ktmracer517 December 18th 2010, 11:42 am
my car is a factory turbo coupe and the ford racing swap motor mounts for a bbf dont look like they will work with my factory lower mounts. So i am not sure if i need a 5.0 lower mount or what....... also what brand headers fit best for the swap any advice would be greatly appreciated
ktmracer517
bb fox motor mounts Empty Re: bb fox motor mounts
Post  studly December 18th 2010, 6:31 pm
I would use D&D that is what i have and i would use a plate instead of motor mounts, more room for the headers
studly
studly
Post  Mark Miller December 19th 2010, 2:55 am
I had a 88 T-Bird V-6 car and the K-Member that was in it would not work with the 460 swap motor kit.I ended up using a 87-93 Mustang K-Member and the Mustang lower front control arms because they're shorter than the T-bird control arms.
Later Mark.
Post  DFI429 December 19th 2010, 3:46 am
ktmracer517 wrote:my car is a factory turbo coupe and the ford racing swap motor mounts for a bbf dont look like they will work with my factory lower mounts.
Mark Miller wrote:I had a 88 T-Bird V-6 car and the K-Member that was in it would not work with the 460 swap motor kit.
I confused myself for a minute thinking about this one, but yes, you have to change out the 6-cyl k-member for 8-cyl use.. Or mount the motor up high for HotWheels-status Shocked
DFI429
DFI429
