Cam gear locating pin broke
+8
DanH
racingfan429
turbosplash
jesse
the1969fordguyinky
12 posters
Cam gear locating pin broke Empty Cam gear locating pin broke
Post  the1969fordguyinky August 30th 2009, 12:09 pm
Alright maybe it isn't called the cam gear locating pin. Is it a dowel pin? Anyway, I was putting the new springs on the heads in the car (installing a roller cam project) and I had one side done, the rockers were all on, but loose as I had not set the lash yet. For whatever reason I wanted to rotate the engine, so I did and thats when the cam pin sheared off. Let me explain, there was NO bolt in the cam, and it was likely not all the way back.
Neutral
So I cussed a bit and then finished out the spring swap on the other side and then decide to drill out the pin. Thats when it got worse. I drilled it out and tapped it and then used a slide hammer to remove the pin, except the pin did not come out. It pulled the threads off of the tiny cheapo bolt. So I drilled a bigger hole and used a bigger tap and then made the best (&*^% of the night when I broke the tap off. Game over, time for bed.
Crying or Very sad
Now for the questions! Does the cam bolt do most of the work holding the gear on? At what spring pressure, RPM, lift or whatever variable should one double pin a cam? AND here is one that puzzeled me, the cam has two pin holes (the gear only has one like all of them I have seen) if there was no pin in the cam how would one know where it wold go??
the1969fordguyinky
the1969fordguyinky
Cam gear locating pin broke Empty Re: Cam gear locating pin broke
Post  richter69 August 30th 2009, 12:17 pm
The pin is really just a locator, the press fit of the gear to the cam is what keeps it from spinning. This is why the bolt and washer are real important. The pin does offer some holding power, but with no bolt pressure like that its doomed.
Post  jesse August 30th 2009, 2:30 pm
i myself have never had one break
but i have seen it happen to other's
now for every build i use 2 pin's
no matter if it is a mild street stomped or a all out race motor
it is a pice of mind if anything
and it isnt very costly to do
i think my comp cam was like 30.00 extra to have the 2nd pin
and i just drilling out the gear
jesse
jesse
Post  the1969fordguyinky August 31st 2009, 10:07 am
Thanks guys.
the1969fordguyinky
the1969fordguyinky
Post  bbf-falcon September 1st 2009, 8:12 am
The Bolt and washer does most of the work. MAKE SURE TO USE A VERY THICK/HEAVY WASHER and torque down good. I use a washer from sbc harmonic balancer.
Post  dfree383 September 1st 2009, 8:45 am
The pin is very important, you need to have one or two prefered. The bolt and washer only holds the gear inplace, the pin / pins allow it the gear to turn the camshaft.
Post  the1969fordguyinky September 1st 2009, 10:08 am
So... Both the pin(s) and the bolt are important. I'm leaning towards double pinning the gear since the cam already has two holes, well one hole and one full of broken tap Rolling Eyes
I have yet to do anything about that, I have a machinist friend that may be able to fix it on the cheap whom I will see tonight.
One question remains, about the pre-drilled pins in the cam, how does one know which is the 'primary' one? It does not appear to be marked on the cam.
the1969fordguyinky
the1969fordguyinky
Post  turbosplash September 2nd 2009, 7:34 pm
2 pins are ok, but another good way which is really good is to add a woodruff key 180* from the pin and have the keyway broached in the gear. You will never have to worry about a broken pin again. Just my $.002
turbosplash
Cam gear locating pin broke Empty what to do
Post  racingfan429 December 22nd 2009, 1:39 pm
I had this happen as well, unfortuneatly it was at about 6000 rpm and 1000', banged some valves, was looking into doing the double pin thing, I am taking it that it something I should get a machine shop to do
Morris
racingfan429
racingfan429
Post  DanH December 22nd 2009, 3:29 pm
the pin does little work, two pins and leave the bolt loose-- 2 broken pins. Now to fix your cam, turn (gear on cam) 180 degrees bolt in down-drill new dowel hole--fixed. cam gear- mark new dot 180* from original , just to make it easy for line up. degree in the cam will be a must.
DanH
Post  tiger December 22nd 2009, 6:22 pm
What is the torq spec on the cam bolt?
tiger
Post  Lem Evans December 22nd 2009, 9:02 pm
I use 45# w/loctite on the 3/8" bolts and 65# w/loctite on the 7/16".
Post  tiger December 23rd 2009, 12:07 am
I have never found the torq spec on the two little bolts that hold cam plate on. Can someone give me that also.
tiger
Post  63boxtop December 23rd 2009, 12:49 am
i did the woodruff key thing and a pin in my set, solid roller cam, then used the SBC harmonic balancer washer as stated above and checked end play, piece of mind i guess
rick
63boxtop
Post  BOSS 429 December 23rd 2009, 12:50 am
should not of tried turing it over with rockers on,and cam bolt not in,ive seen 3 people do this,brake dowel off
