500HP+ top end complete
I've got this setup for anyone who is looking for a complete top end:
Ported D3's with CJ valves
Scorpion pedastal mount roller rockers
Port matched Performer intake(nicely done)
780 Holley Street Avenger carb. Elec. choke. Vacuum secondaries
Custom length comp cams pushrods
Hyd. cam and lifters. Nice choppy idle with good vacuum. Pulls hard to 5500-6000
This is a complete setup that will get you at least 500HP. I'm running flat top pistons and am right around 10:1 compression. The car made 450 lbs of torque at the wheels at 4K. Engine is in the car at this time. I'm wanting the new TFS 325 heads and a big solid roller so I need to sell this stuff first. I'm just north of Nashville, TN.
975.00 plus the ride. six one five 476-9100. Merry Christmas!
Last edited by 738drvr on December 24th 2010, 3:29 pm; edited 1 time in total (Reason for editing : title)
738drvr- Posts : 600
Re: 500HP+ top end complete
5 day bump.
You don't have to waite 5 days here just don't bump every few hours
Cam specs:
Crane
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,500-5,500
Intake Duration at 050 inch Lift 226
Exhaust Duration at 050 inch Lift 230
Duration at 050 inch Lift 226 int./230 exh.
Advertised Intake Duration 288
Advertised Exhaust Duration 292
Advertised Duration 288 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.522 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.530 in.
Valve Lift with Factory Rocker Arm Ratio 0.522 int./0.530 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible No
Grind Number H-288-2
Crane
Still for sale.
Bump up.
[i]
I came out alot better by selling mine off seperately might work for you too.
» Fs or FT 302 Blow Thru 500hp
» Looking for a complete 390
» Complete 460
» Complete engine
» 408 windsor complete
» Complete 460
» Complete engine
