Cap walk on A460
+8
Oakley Motorsports
342g
56Tbird
12 posters
Cap walk on A460
Talked to guy that engine builder found signs of just a little bit of cap walk during bearing inspection on high reving 500" BBF. Have any of you seen this before
Re: Cap walk on A460
Yep, Keown's old engine had it. Excessive timing and high RPM's...It can be done if you try hard enough
56Tbird- BBF CONTRIBUTOR
The caps can't really walk around because they're pinned however, some metal transfer can still take place if they bounce or excessively vibrate.
Detonation is the usual culprit.
I guess that's like walking in place,stepping without moving.
If you are speaking of Terry's engine......Phillip and I looked at it saturday.......there is no issue.
56Tbird wrote:I guess that's like walking in place,stepping without moving.
We called that marking time in the army, I believe it is treading water in the navy.
342g- BBF CONTRIBUTOR
My stuff never makes enought power to have cap walk. Not yet........
cletus66- Posts : 865
Actually looked at that block on purpose because of the high rpm and it looked awesome. No concerns at all.Lem Evans wrote:If you are speaking of Terry's engine......Phillip and I looked at it saturday.......there is no issue.
Oakley Motorsports- BBF VENDOR SPONSOR
^^^^^^well there ya go.............no need for concern folks................
What rpm level are we talking here?
738drvr- Posts : 600
everything has its limit ...... its racing guys
605FOX- BBF CONTRIBUTOR
cap walk is never an issue to me.when they stop walking and start running you have a mess!
I've never seen it on the three center caps, but I've sure had issues on the two end caps. The problem... too lean/too much timing (mean tune) and RPM.
Bret
Bret
Bret Powell- Posts : 133
Bret,can too lean cause it.i can see the timing causing it but can too lean,alone,cause it.Bret Powell wrote:I've never seen it on the three center caps, but I've sure had issues on the two end caps. The problem... too lean/too much timing (mean tune) and RPM.
Bret
With 15+ to 1 compression and 8500+ rpm too lean can cause some pretty serious detonation no matter what octane fuel you run. So to answer your question... Yes. This is truck pull stuff with iron heads. Which I think the iron heads can also contribute to the problem for the fact they will not pull the heat out of the chamber like aluminum heads will.
Bret
Bret
thanks for the info Bret.good to know.Bret Powell wrote:With 15+ to 1 compression and 8500+ rpm too lean can cause some pretty serious detonation no matter what octane fuel you run. So to answer your question... Yes. This is truck pull stuff with iron heads. Which I think the iron heads can also contribute to the problem for the fact they will not pull the heat out of the chamber like aluminum heads will.
Bret
» A460 main cap pins - what are they for, locating, cap walk, ?
» cam walk
» 460 cap walk
» cap walk
» question on compression ...using pump gas (a460...using fms a460 heads)
» cam walk
» 460 cap walk
» cap walk
