Jim's Little 460 AND 2000 RANGER
+49
bigblok2000ranger
whitefield
Ammosteve
larry552
1970 ford maverick
nitrous.f
OldRed70
Tony M
kjett
AZFairlane
manofmerc
ribald1
audietorino72
72mav
bb429power
ThndrChkn
8liter
557 mazda
jones
adrenaline269
RapidRuss
'65 T-BOLT
bigjohn2007
hay hauler john
lghting94
torkair
danger ranger
Slaughtrhousjak
BBFmustang
OldRedFord
ndmus88gteng
501ranger
Greg_P
westsideford
Old blue Racin Team
Northwest outlaw
53 posters
Page 10 of 20 Previous  1 ... 6 ... 9, 10, 11 ... 15 ... 20  Next
Jim's Little 460 AND 2000 RANGER - Page 10 Empty Re: Jim's Little 460 AND 2000 RANGER
Post  69F100 April 27th 2010, 8:31 pm
Nick yes I have added 1 more to it just haven't posted anymore pics I have about got the rear ready to paint the chassis and sheet metal it .The bars look alot longer than they are I think if I rememder right they are 58" long.I have about 6 or 8 small pieces of tubing to weld in the bed area for the sheet metal. Then I am going to get started on framing out for the seats and sheet metal on the inside.Went to summit last weekend and picked up 2 seats the cheap summit seats for now.
Jim's Little 460 AND 2000 RANGER - Page 10 04-24-10_1647
Jim's Little 460 AND 2000 RANGER - Page 10 04-24-10_1231
Jim's Little 460 AND 2000 RANGER - Page 10 0427001854
Post  69F100 May 1st 2010, 8:24 pm
Just alittle update getting closer
Jim's Little 460 AND 2000 RANGER - Page 10 0501001819a
Jim's Little 460 AND 2000 RANGER - Page 10 0501001820-1
Post  69F100 May 2nd 2010, 5:20 pm
Forgot one
Jim's Little 460 AND 2000 RANGER - Page 10 0426001844
The new look
Post  Northwest outlaw May 2nd 2010, 10:44 pm
look good you be done in no time.
Northwest outlaw
Northwest outlaw
Post  69F100 May 24th 2010, 9:38 pm
Just alittle update got my 5 point seat belts from speedway motors made some seat mounts at work for the seats. I had to add another bar behind the seat for the belts to bolt too when I welded the bar behind the seat on the cage I put it to low for the seat belts.If I would had bolted the belt to it the belt mount would have 6 1/2" below my shoulder the rule book said it could only be 4" below.With the new bar it will be level with my shoulder and that is how the layout for the belts shows and nhra rule book shows. Don't want to cut corners on safety hope I never need any of it but want it right just in case.Now I like building gas padel and getting the bracket for it welded in and linkage rod to carb built I hate cables.Then I can repaint chassis and cage and get started to the aluminum sheet metal.
Jim's Little 460 AND 2000 RANGER - Page 10 0524002010
Post  69F100 May 30th 2010, 3:12 pm
Got a few of the little things done yesterday the little things seems to take longer than the bigger ones well got the control panel for the switches installed, brake pedal moved over,gas pedal made and linkage for it,the shifter stand welded in,and my belts bolted in and seats if I have to bolt the seats in and out to many more time I am going to have to buy new bolts.But that is part of getting everything mocked up and right the fun part of it all Rolling Eyes .I am debating on lowering the front end next or painting the cage and chassis again after adding the rest of the tubbing and 4 link .It will mostly depend on the weather for witch one is next calling for rain the rest of this week.So I will more than likely do the frontend no money involved in lowering it.I need to buy some of them cheap traps to cover the cab and engine before painting man I am sure ready to finish the cage.Then the aluminum sheet medal work begains.
Jim's Little 460 AND 2000 RANGER - Page 10 0529001352
Jim's Little 460 AND 2000 RANGER - Page 10 0528002012
Jim's Little 460 AND 2000 RANGER - Page 10 0529001355a
Post  69F100 June 6th 2010, 4:44 pm
Got the front end lowered 2" it is now 7" off the ground
Jim's Little 460 AND 2000 RANGER - Page 10 0604002036
Jim's Little 460 AND 2000 RANGER - Page 10 0604002033
Post  69F100 June 30th 2010, 6:39 pm
Just alittle update,I have managed to get alittle more done on it got the stall convertor put in ,hood pins installed,and should have the drive shaft put in by the weekend.Then maybe I can get started on the chassis paint and finish painting the cage and get started on the sheet metal.
Post  res0rli9 June 30th 2010, 6:54 pm
Still looking good. your almost there cheers Cool
Keith
Post  69F100 July 12th 2010, 11:08 pm
I sold my holley dizzy and replacing it with a MSD 6AL and Durospark Dizzy I needed a rev limiter.I ordered a new MSD 6AL tonight as soon as I get it and go get my drive shaft if I ever get off work in time.I am going to try to finish the paint on it for I can start the insides.The wife's van put a damper on things for alittle but maybe I am getting back on track now.
Post  8liter July 13th 2010, 11:16 pm
Looking good....
8liter
8liter
Post  69F100 July 24th 2010, 9:16 pm
Well managed to get alittle done the MSD 6AL and Durospark dizzy in got the timing set.Got the truck back to the house today and got it took apart and bars primed in ready to paint.
Jim's Little 460 AND 2000 RANGER - Page 10 0724001716
Jim's Little 460 AND 2000 RANGER - Page 10 0724002033
Post  ThndrChkn July 25th 2010, 11:42 am
Lookin' good there Jim. Almost there. Cool
Doug... Cool
ThndrChkn
ThndrChkn
Post  69F100 July 28th 2010, 12:56 pm
Finished the cage and chassis paint now to put it back together again one thing I will know every bolt on this truck for sure but that is part of building it your self. cheers
Jim's Little 460 AND 2000 RANGER - Page 10 0727002029
Post  69F100 July 28th 2010, 1:46 pm
Take a day off work to take care of some stuff and get my truck put back together and get some panels cut and fitted for I can carry them to work and use the brake to bend the bed panels.Sun out raining like crazy with dark clouds and thundering coming can hear it in the back groumd.I can't even take off work to work on the truck one day I will build a shop at the house I can work in one day,in stead of under a trap.Yes it was in Rick's shop but I brought it home to finish the painting under the trap and do the sheet metal.Well heres the flooding part with the t-storm and lightening better get off here.
Jim
Post  bb429power July 28th 2010, 3:14 pm
I hope you git r done soon! She's looking sweet, didn't you say you were going to get taller wheels for the back? Bigger diameter one's should fill the wheel well better and give it an awesome look.
bb429power
bb429power
Post  69F100 July 28th 2010, 6:35 pm
Yes I will be putting 31x10.5x15 on it when I finish with the build these are some stock car tires my brother gave me for mock up.Might do a big burn out with them before I pull them off for the fun of it.
Post  bb429power July 28th 2010, 9:40 pm
69F100 wrote:Yes I will be putting 31x10.5x15 on it when I finish with the build these are some stock car tires my brother gave me for mock up.Might do a big burn out with them before I pull them off for the fun of it.
Video tape that! Twisted Evil
bb429power
bb429power
Post  69F100 July 29th 2010, 11:23 pm
Just a couple update pics got one panel put in the bed I got the others cut out and carrying them to work tomorrow to bend in the brake should finish the bed this weekend.
Jim's Little 460 AND 2000 RANGER - Page 10 0728001756
Jim's Little 460 AND 2000 RANGER - Page 10 0729001900
Post  69F100 July 30th 2010, 10:21 pm
Well got the sides and the front done tonight I will put the floor of it in tomorrow and the bed will be finished then it will be time to make the firewall that will be the hardest as I don't want to pull the engine back out but they may not be any way around not pulling it except taking the windshield out.It is going to come out later when I buy the lexan but don't want to take it out until then.
Jim's Little 460 AND 2000 RANGER - Page 10 0730002104
Jim's Little 460 AND 2000 RANGER - Page 10 0730002058
Not the best pics they are from my cheap call phone
Post  res0rli9 July 31st 2010, 4:29 pm
Looking Real Good Cool
Post  69F100 July 31st 2010, 10:47 pm
Here is a pic in the day light my cell don't take to good at night I put the cables on the tailgate and couldn't hold on to the tailgate for it be so hot
Jim's Little 460 AND 2000 RANGER - Page 10 0731001659
Post  69F100 August 2nd 2010, 9:47 pm
Should finish to bed tomorrow got to pick up some alum trim from work to do alittle trim work and cut out for battery try and fuel cell.With the bed setup this way it gives me 16" clearance at the closest point in the wheel wale.The bed might way 100# no more than 125#
Jim's Little 460 AND 2000 RANGER - Page 10 0802001927
Post  bb429power August 2nd 2010, 10:28 pm
Cool cool cool! I love drag trucks! I'm going to have the heaviest drag truck on here when its done Laughing Haven't done anything to lighten it.
bb429power
bb429power
Post  69F100 August 4th 2010, 8:44 pm
Got the bed finished all but seam sealing with aluminum caulk but that will be after I/we finish the inside.Now time to start the hard part the firewall after the firewall the rest want be that hard.
Jim's Little 460 AND 2000 RANGER - Page 10 0803002043
