Jim's Little 460 AND 2000 RANGER
+49
bigblok2000ranger
whitefield
Ammosteve
larry552
1970 ford maverick
nitrous.f
OldRed70
Tony M
kjett
AZFairlane
manofmerc
ribald1
audietorino72
72mav
bb429power
ThndrChkn
8liter
557 mazda
jones
adrenaline269
RapidRuss
'65 T-BOLT
bigjohn2007
hay hauler john
lghting94
torkair
danger ranger
Slaughtrhousjak
BBFmustang
OldRedFord
ndmus88gteng
501ranger
Greg_P
westsideford
Old blue Racin Team
Northwest outlaw
53 posters
Page 15 of 20
Page 15 of 20 • 1 ... 9 ... 14, 15, 16 ... 20
Re: Jim's Little 460 AND 2000 RANGER
Northwest outlaw wrote:cool deal.
Norhwest where you been haven't notice you on in awhile
Had to take a brake from cars and truck had some helth problems but all is good now so i have slowly been get back to speed on things.
Northwest outlaw- Posts : 962
Northwest outlaw wrote:Had to take a brake from cars and truck had some helth problems but all is good now so i have slowly been get back to speed on things.
glad you are ok , welcome back
Do you still have your mustang
got some more parts 4,30 gears and 2 sets of springs now to get time to get it back to the track to see how the head swap helped.this winter plan is to upgrade the frontend engine and put the gears in
your bad as me! i change something every time i go to the track!
yep and forgot about the new engine build also over the winter looking for some 6.0s hopefully and maybe some 9.s in the 1/4
The ranger will be getting a 92 cid upgrade to a 552 might take alittle longer than planned on for this new engine build over the orginal plan on the 466 but that is fine.The 552 will be easier to meet my hp level of 700 and not work the engine as hard for less maintenence in the long run.Just need to keep working the OT so I can finish buying the rest of the parts I need.
big is never too big!
bump for kjett
69F100 wrote:bump for kjett
Thanks!!
kjett- Posts : 1169
got 2 more parts for it this week a ATI super damper and another carb 1150 for gas and for brake in and if I need it to move the truck around with instaed of having to burn 3 gallons of alky just to move it around at the house
Got a new CSR Flex plate this week if nothing changes before next weekend I will be heading to SC I will be carring the rotating assy,and block to the machine shop.I will be ordering the comp roller lifters and comp timing set in the morning.That will leave just a few thing to order to be able to start putting it together when it get back from the machine shop.Still need to find a good rear sump 9qt oil pan before buying oil pump for I will know witch pump I need.I need head gaskets,valve springs more than likely new pushrods oh ya new timing cover the one that was on the engine broke from a crack that was in it.
Well UPS brought me some more goodies today got new comp cam endure solid roller lifters and comp cam billet 9 key timing set block and rotating assy at the machine shop.This weekend I will be ordring new timing cover and head gaskets then I should have everything to put the short block together except oil pump and pan.Still trying to figure out what pan I want to use before buying the oil pump.
OK got my stuff back from the machine shop now it time to start the building
Sounds like its going to be a nice build.
Tony M- Posts : 479
Thanks Tony
I have the crank,pistons/rods,cam,and timing set installed in the block waiting on oil pump.I ordered a new pump and pickup my wife picked it up for me today while I was at work.She dropped it off at work to me I pulled the pump out it was a front sump oil pump with the front sump pickup and the pickup tube I ordered was right it for the rear sump.I order it for a 94 f250 with a 460 in it from Advance Auto plus the oil pump someone has already used a grinder on it the mounting holes are rounded and not flat from grinding.
Here is the link to the 552 build https://www.429-460.com/t17060-a429-552-bbf
The 4.30 gear is in,new u joints in, working on the brake system now trying to get some better brakes on it before I turn it loose and do some tnt passes.The engine is ready for the alky just need to put the alky carb on ran out of time today working on the brake system.I finished off one of the brackets that holds the hold the cal on 1 of the holes stripped out where the bolt that the cal slides on. So I decided to go ahead and put the RX7 rear disc set up I have on it plus it alot lighter than the linc town car set was on it.I got to get the center of the rotors milled out to fit over the axle tomorrow good to have a friend with bridgeport and a lave close. Then get everything lined up and bolted on and put the new MC on it and get the brake working good.Then a burnout
pics of the new rear disc brake setup
work...work...work.. look'n good Jim!
Engine is strong but having some fuel problems it starts leanng out just above 5000 rpm called ADP he told me a few things to check if that don't work sending it back to them to be freshen up.He will go thro it and set it for my engine he said it sounded more like it might need jetting up a few sizes.He wants me to start at 188 and go up to 192 jets so I will order some new jets and try to jet it up to see what happens.
Don't remember right off hand what size I have in it now but they are what ever was in it when Jon had it.
Oh ya I did leave a pare of black marks in front of Rick's house but they are light so not very noticable
I might go with a tolit talked with a guy today about trading my 1150 dom and new fuel pump for a 4" flying tolit setup. if we make the trade I will be saling the 1050 APD alky carb .
» Jim's Little 460 AND 2000 RANGER
» 2000 Ranger chassis
» Let's see your ride(s)
» 2000 Ranger frontend swap to a tube strut frontend
» intro manofmerc
» intro manofmerc
Page 15 of 20
