piston advice
piston advice Empty piston advice
Post  bigunitmudracing January 16th 2011, 6:55 pm
I am going to buy good pistons, this is a race engine so compression is a good thing..... i can only run a flat top piston , no dome...
i have a c9 block and i do not want to cut the deck at all,... looking for a good LIGHT WEIGHT piston .060 over
so, anyone know what brand , maybe a part number... forged pistons, flat top, light weight,and higher compression hight to be at zero deck..
thanks
bigunitmudracing
bigunitmudracing
piston advice Empty Re: piston advice
Post  bbf-falcon January 17th 2011, 9:50 am
If its a flat top and you wont cut the block,the cr will be dictated by your heads combustion chamber and cutting the head surface. You should probably at least clean up the surface of the block imo.
Post  dfree383 January 17th 2011, 10:07 am
Probe has some decent on the shelf pistons.
