cool dyno tool ...
+8
DanH
fatal addiction
bb429power
AZFairlane
12 posters
cool dyno tool ... Empty cool dyno tool ...
Post  bruno January 19th 2011, 10:17 pm
Randy M. you got one of these ????
cool dyno tool ... Clearpan1
http://WWW.CKRME.COM
cool dyno tool ... Empty Re: cool dyno tool ...
Post  69F100 January 19th 2011, 10:26 pm
something like that would make good way to test a new oil pan design make it out of lexan first to see how the oil flows with the new design.
Jim
Post  bruno January 19th 2011, 10:28 pm
69F100 wrote:something like that would make good way to test a new oil pan design make it out of lexan first to see how the oil flows with the new design.
Jim
or even testing new windage designs Wink
Post  BOSS 429 January 19th 2011, 10:47 pm
now we could install it in a car with a vid cam
Post  AZFairlane January 19th 2011, 10:48 pm
What's the melting point of Lexan?
AZFairlane
AZFairlane
Post  bruno January 19th 2011, 10:57 pm
AZFairlane wrote:What's the melting point of Lexan?
the temp of the oil is well below the melting point of the pan ....... it will not work on a street car or drag car ...works well in a dyno scenario ....also works well in custom crank arm designs Wink
Post  69F100 January 19th 2011, 10:59 pm
not sure on the melting point might check and see if i have some scrape at work tomorrow on some 1/4'' thick lexan got some 1/8 here at the house might check a peace of it i have a inferred temp gauge see what it say the melting point is
Jim
Post  bb429power January 19th 2011, 11:07 pm
That and a lexan set of valve covers is Cool for the dyno. What's next? a lexan carb spacer to watch A/F flow? Neutral Some good ideas out there.
bb429power
bb429power
Post  fatal addiction January 19th 2011, 11:26 pm
when u get the valve covers done let me know how much to rent everything for when i dyno mine Cool
fatal addiction
fatal addiction
Post  bb429power January 19th 2011, 11:29 pm
fatal addiction wrote:when u get the valve covers done let me know how much to rent everything for when i dyno mine Cool
I was going to take my stock covers, cut the top off, then make brackets and bolt a plexiglass top on it. Decided not to, at least for this build.
bb429power
bb429power
Post  maverick January 20th 2011, 6:48 am
Nick....Do you know what that on is actually made of? If it's Lexan, it must be calendered (laminated with something else) Distortion temp of Lexan (or any polycarbonate) is about 275*F. That's the point at which it will BEGIN to soften. Forming temp is higher, around 375 - 400* F. Problem is, if made of polycarbonate, it won't be a long-lasting piece, as all manufacturers of PC will tell you to avoid exposure to petroleum, especially at elevated temps. Petroleum attacks PC (clouds, crazes, cracks) in fairly short order. Acrylics will begin to soften at a slightly lower temp, but are more solvent resistant. I'd think there's a good grade of tempered glass out there that would do the job.
I've often thought of making stuff like that, but haven't seen the right thermoplastic yet. Tooling for thermoforming would be cheap, but the durabilty issue......Nah. Then again, if I made enough of 'em, I could run it a couple of times and toss it.
Thanks a lot, you guys.....Now I got this crap cooking in my head again. Rolling Eyes
Post  DanH January 20th 2011, 8:09 am
years ago they had valve cover for sbc , plastic see through , couldnt see a rocker or spring when running
DanH
Post  bruno January 20th 2011, 8:28 am
video coming soon
Post  dfree383 January 20th 2011, 8:40 am
Cool, it has been done before along with cameras,
Post  birdracer January 20th 2011, 5:33 pm
I have watched a similar unit in use on a 460 at EMDO (engine manufacturing and development office),ford motor company some years ago..the engineering types were studying oil pump/pick up tube harmonics/movement with a strobe photo arangement..I was shocked...not suprising the oil pumps break!...Brian
birdracer
Post  fe50stang January 20th 2011, 8:44 pm
on the FE forum one member put a clear 1 1/2 tube in the top and bottom of the pan so he can see where his oil was in the pan on the dyno. He was worried he would suck the pan dry after a 9 seconds of full throttle. Long story short he was loosing oil pressure at the big end of the track and could not figure out if he had oil drain back issues, or if he was sucking the sump dry or widage issues. by putting a clear tube from top to bottom of the pan it showed what was going on with oil levels and answered all of the questions. Ill see if I can drum up a couple of pictures. It might make more sience
fe50stang
fe50stang
Post  Outlaw5.0 January 21st 2011, 4:09 pm
I have seen many of oil pans at work with "window" and etc.
Outlaw5.0
