maintence finds .....
+16
Larry Williams
frank13
Wheelie58
LivermoreDave
powerstrokeace
20 posters
maintence finds ..... Empty maintence finds .....
Post  bruno July 11th 2010, 2:26 pm
so with some of Dan's recent failures i finally decide to ck things out on my build..this will be the first time in almost 2 years im cking things out ....yes very lazy ..... the first thing that i noticed is that my valve lash is way off , im going to find a valve spring tool to ck pressure and retorque the heads as per C. Evans other then that oil pressure has been great since day 1 so i will give her an oil change and be ready for the ODRA and ORTC events
later guys
http://WWW.CKRME.COM
maintence finds ..... Empty Re: maintence finds .....
Post  bruno July 11th 2010, 2:33 pm
n/m valve lash is perfect ....was reading the gauge wrong Embarassed .... mm instead of inches ....
Post  res0rli9 July 11th 2010, 2:35 pm
Smile Cool
Post  138 July 11th 2010, 3:30 pm
is that all you did...was check valve lash... Razz
138
Post  cool40 July 11th 2010, 9:55 pm
if it aint broke,dont fix it! Laughing
Post  dfree383 July 11th 2010, 10:20 pm
Springs and lifters are cheaper than motors.....
Post  bbf-falcon July 11th 2010, 10:47 pm
How many passes on the engine Nick Question
Post  richter69 July 11th 2010, 11:02 pm
bbf-falcon wrote:How many passes on the engine Nick Question
not enough to need springs and lifters..........
Post  bbf-falcon July 11th 2010, 11:11 pm
Thats why I ask the Question
Post  bruno July 12th 2010, 7:51 am
47 passes plus the dyno time
Post  bruno July 12th 2010, 7:52 am
the springs/lifters were used in the last engine
Post  dfree383 July 12th 2010, 8:08 am
how many total passes?
Post  bruno July 12th 2010, 8:11 am
dfree383 wrote:how many total passes?
250 plus ......
C. Evans cked all the spring pressures while he had the heads in his possesion
Post  dfree383 July 12th 2010, 10:04 am
time to put some springs and lifter in IMO, keep the springs for spares and send the old lifters (if they are comps) back for a rebuild and keep them for spares and use them next change.
Post  bbf-falcon July 12th 2010, 11:12 pm
dfree383 wrote:time to put some springs and lifter in IMO, keep the springs for spares and send the old lifters (if they are comps) back for a rebuild and keep them for spares and use them next change.
XXXXXXXX222222222 Smile
Post  powerstrokeace July 12th 2010, 11:20 pm
I have close to 200 runs on the springs and they are breaking left and right . Or every time I run the car. But there 10 years old.... New set on the way for the National next week end. Comp Cams 947's
Ace
powerstrokeace
powerstrokeace
maintence finds ..... Empty TOOL TIME!
Post  LivermoreDave July 14th 2010, 6:50 am
Nick, here's a good starting point!
Dave.
maintence finds ..... LSM
LivermoreDave
Post  whatbumper July 14th 2010, 2:22 pm
we rebuild lifters and replace rods and springs every year and will look at the valves in about 2 seasons. kind of sucks but it is cheaper than a block and messing up a bryant crank.
aluminum rods
nextek springs 320lbs seat pressure
8000-8300 rpm
the rods and springs go to local guys building NA engines. Very Happy
the Maverick with a 306 bracket motor went over 700 passes without doing anything but change the oil and plugs every now and then. speed cost a &hit load of $$$$$$$$$$
Post  bruno July 17th 2010, 9:05 am
so what you guys are saying is that i need to put this sucker up till i replace those parts ........
maintence finds ..... Empty LSM Tools
Post  Wheelie58 July 17th 2010, 10:15 am
LivermoreDave wrote:Nick, here's a good starting point!
Dave.
Dave's suggestion of the LSM tool is a solid one.
I bought their spring tester and their on-engine spring compressor last year.
It is not often that you buy something and are 100% delighted with the performance of the product. This is one that blew me away.
They simply make good tools.
I helped a fellow 460 guy test his springs and replace all 16 springs at the track last year, using the LSM tools.
It seems like we were done in less than 1.5 hours.
Keith
www.KeithFulpMotorsports.com
Wheelie58
Wheelie58
Post  bruno July 17th 2010, 10:18 am
Were can i get one ??? do i need to get it direct from them ...
Post  frank13 July 17th 2010, 10:43 am
http://www.lsmproducts.com/pc100slc.htm
you can order right from them unless you can find it cheaper
frank13
frank13
http://www.frankskinkracing.com
maintence finds ..... Empty Just call LSM
Post  Wheelie58 July 17th 2010, 11:33 am
frank13 wrote:http://www.lsmproducts.com/pc100slc.htm
I would reccomend calling them direct. There are variations in the tools depending on which heads and rockers that you use.
You can get the right stuff the first time if you call LSM. 916-632-2692.
Summit sell their tools....also.
Keith
Wheelie58
Wheelie58
Post  bruno July 18th 2010, 6:24 am
so what are the best springs to buy ? and the best lifters ?
and is that tool in the pic.. goona allow me to test the springs and remove them also ??
Post  Wheelie58 July 18th 2010, 7:45 am
bruno wrote:so what are the best springs to buy ? and the best lifters ?
The spring/Lifter brand question will be a controversial one. I can just say that my 514 has done well with Lunati lifters, but it has an itty bitty cam. It has always used K-Motion K1000H springs and when the engine was in the car all of the time, they would last about 3 seasons. (650 lift)
The 605 is closer to .800 lift and it uses PSI springs from CV products the number is not anywhere close by....but it a one of their "dual drag springs".
As close as I can tell, they last about 125 to 150 passes. That engine has Crower lifters in it.
The tool in the previous picture is just for on-engine testing.
The removal tool is a different one having several options depending on your head and rocker setup. You can see them all on the site. Here is one for stud mount.
http://www.lsmproducts.com/sc800.htm
They are rather expensive, but work nicely.
Thanks,
Keith
Wheelie58
Wheelie58
