maintence finds .....
+16
Larry Williams
frank13
Wheelie58
LivermoreDave
powerstrokeace
20 posters
Page 2 of 2 Previous  1, 2
maintence finds ..... - Page 2 Empty Re: maintence finds .....
Post  dfree383 July 18th 2010, 11:13 am
I'd agree with Keith on the controversy on brand as every on has thier preference.
I like And use the Comp Cams Lifters, But IMO Isky, Crower, LSM and Jesel are all top rate.
As far as springs their are alot of good one, it's a matter of getting the right one and frequency for your valvetrain. And paying attention to them.
Post  Lem Evans July 18th 2010, 11:49 am
blue stripes like Ky Jell has on his P51 deal.
Post  richter69 July 18th 2010, 12:13 pm
Blue stripe for the win........ cheers
Post  Larry Williams July 18th 2010, 12:29 pm
which springs do the P51's come with?
Larry Williams
Larry Williams
Post  Lem Evans July 18th 2010, 12:39 pm
They can be what ever fits a guys application.
Post  IDT-572 July 18th 2010, 1:16 pm
Several of us are using the blue strip spring Lem sales and have had no problems, it's a very good spring. Well suited for our cams and lift we run.
Post  dfree383 July 18th 2010, 4:31 pm
Ran them in both EMC motors last year, have them in my A460 Motor and Karl has a set in his Iron headed mud drag truck.
Post  bruno July 19th 2010, 9:36 pm
so who is driving down to alabama to change my springs for me cheers room, board and food for a weekend ...ask Dan i feed well Laughing
http://WWW.CKRME.COM
Post  powerstrokeace July 20th 2010, 12:00 am
powerstrokeace wrote:I have close to 200 runs on the springs and they are breaking left and right . Or every time I run the car. But there 10 years old.... New set on the way for the National next week end. Comp Cams 947's
Ace
Spring are done and truck and trailer's in line for the mile highs nationals
Ace
powerstrokeace
powerstrokeace
Post  c.evans July 20th 2010, 1:43 am
bruno wrote:so who is driving down to alabama to change my springs for me cheers room, board and food for a weekend ...ask Dan i feed well Laughing
Maybe,,,,,just maybe,,,,,you should hire a crew chief. Razz
Step 1. Buy a valve spring checking tool. Even the cheaper Moroso beam type unit will work for this.
Step 2. Buy a Moroso rocker stud mount valve spring compressor. Reinforce, brace and weld the tangs on it, because they will bend & break. The much better Manley piece has been discontinued.
Step 3. Buy a short little air hose with the 14mm spark plug thread on the end of it, in order to pump air into the cylinders.
Step 4. Buy an air compressor to pump air into the cylinder to hold the valve up while you change the spring.
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  dfree383 July 20th 2010, 4:57 am
And bump each cylinder to tdc while changing just in case.
Post  Nevs July 20th 2010, 6:20 am
dfree383 wrote:And bump each cylinder to tdc while changing just in case.
X2, don't trust the air pressure to hold the valves closed....don't ask me how I know............. Laughing
Post  IDT-572 July 20th 2010, 9:17 am
I just put the piston at top dead center and go on and change them with no air.
With the piston at TDC and the good positive stop seals on it the valve wont move, and if it does it wont go far.
Post  c.evans July 20th 2010, 11:10 pm
IDT-572 wrote:I just put the piston at top dead center and go on and change them with no air.
Blake,
I know that traditionally most of us "rap" the retainer with a dead blow hammer in order to break the locks loose. We still need to do that, however I've noticed that with the kinds of valve spring pressures we are running nowadays, that it is best to have air pressure against the valves when you rap the retainer, and also when you are depressing the retainer down, so that you don't move everything including the valve itself.
Another hint is that you don't leave a ratchet or breaker bar on the crankshaft bolt when you are applying the air pressure with a quick connect coupler. If the piston is not exactly at TDC, the air pressure will drive the piston down in a hurry, and in the process turn the crank in a hurry Exclamation
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  kjett July 20th 2010, 11:34 pm
lol Charlie. I saw that happen before. made me laugh my simple ass off. I need to get a better sping compressor. I have a cheapy one i picked up from the Matco guy that I used to have to tighten the knob to compress the spings. Now it has an old socket welded to it and I hit it with the air ratchet Wink
One of these days I'll spend some money and get a rocker stud mount compressor and call it good.
Oh, and gotta love them blue stripe springs. Very Happy
kjett
kjett
maintence finds ..... - Page 2 Empty TOOL KIT.
Post  LivermoreDave July 21st 2010, 9:43 pm
Add to your list of tools, that travel with you to the track where an air compressor may not be available in case you need to change a valve spring ..... a long piece of nylon rope just smaller in diameter than the spark plug opening. Remove the spark plug and insert the rope into the cylinder via the spark plug opening and roll the piston to or near TDC (until it stops), the valve won't go anywhere even if it does get loose from the seal!
Dave.
LivermoreDave
Post  powerstrokeace July 21st 2010, 9:47 pm
How about some information on the Blue Stripe Spring???
Ace
powerstrokeace
powerstrokeace
Post  Mark Miller July 21st 2010, 11:52 pm
I was changing my springs this year and my buddy shut the switch off for the compressor on accident.Talk about freaking out when i went to change a valve spring.
Later Mark.
Post  c.evans July 22nd 2010, 1:32 am
powerstrokeace wrote:How about some information on the Blue Stripe Spring???
Ace
Blue stripe is just our country boy designation of the spring becaue of the paint stripe. It is actually a Manley NexTek # 221424 double with a 2.000" installed height and it comes on the assembled new style TFS A-460 heads. Lem also uses it on his assembled P-51 heads that are intended for big roller cams and racing. Sig Erson also sells this same spring, but I never can remember the part #.
Specs are; seat = 250/260 lbs., open = 800/810 lbs. @ 1.150", rate = 650 lbs., coil bind = 1.070", o.d. = 1.640", i.d. = .860", max lift = .870/880".
It is better to operate a valve spring closer to coil bind (about +.060" away from coil bind), than not to operate it close enough. I use it in Kristina Lawyer's 598 A headed engine, in Bobby Shrewsberry's 559 P-51 headed engine, and in many other customer's heads. I've had excellent service life out of them.
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  windsor July 26th 2010, 2:58 am
kinda off topic, but any of you fellas use CO2 for portable compressed air? Like the PowerTank? Things are awesome and very portable
http://www.powertank.com/
maintence finds ..... - Page 2 403.1168.300x200.FB10-5250
