valve spring tool
Wheelie58
Race Ready Fabrications
mitch
valve spring tool Empty valve spring tool
Post  mitch January 27th 2011, 2:15 pm
who makes a good tool for removing/installing valve springs?
mitch
valve spring tool Empty Re: valve spring tool
Post  dfree383 January 27th 2011, 2:19 pm
Moroso Stud mount one is pretty damn nice, Proform makes a cheaper version of it, but it need some work / modification to keep up with big roller springs.
Post  Race Ready Fabrications January 27th 2011, 2:50 pm
Brad at Buxton Engineering makes some beautiful valve spring tools. Probably the nicest I have seen. Check him out at www.buxtonengineering.com
Post  dfree383 January 27th 2011, 2:52 pm
The Buxton stuff is damn nice, but they aren't inexpensive.
valve spring tool Empty Cool Tool
Post  Wheelie58 January 27th 2011, 4:15 pm
LSM is my favorite.
I also have a Moroso that works well with stud mount systems.
Keith
Wheelie58
Wheelie58
Post  f250mike January 27th 2011, 11:08 pm
Great post mitch,
I have been thinking about valve spring compressors also.
Does anyone have any experiance with the Summit brand compressor? It looks like a copy of the Moroso and Proform ones.
I like the looks of the high end stuff Like LSM, but I can't see buying one for use once every 3 or 4 years.
Just need something that's going to work and not be a total POS.
mike
Oh ya not sure which type mitch is looking for but I need one for on engine spring changes.
f250mike
f250mike
Post  dfree383 January 28th 2011, 7:11 am
The summit one is a Proform, need some work to the foot to make it useable with heavy springs. It will just bend with anything over a decent performance Flat tapped spring.
Post  f250mike January 29th 2011, 9:12 am
Thanks Dave
I have some Comp 930 springs I need to install.
Gonna give the summit/proform deal a try I guess.
Here's the spring compressor I made a few years back.
It needs tweeked on a bit so 3 hands aren't needed to use Rolling Eyes .
Probably should just fix and use what I have.
valve spring tool Springcomp1
f250mike
f250mike
Post  TravisRice January 29th 2011, 10:58 am
dfree383 wrote:Moroso Stud mount one is pretty damn nice, Proform makes a cheaper version of it, but it need some work / modification to keep up with big roller springs.
Race Ready Fabrications wrote:Brad at Buxton Engineering makes some beautiful valve spring tools. Probably the nicest I have seen. Check him out at www.buxtonengineering.com
I have the Buxton on head compressor and a Moroso that I adapted to use on shaft rocker stands also. Both have their own purpose. I use the Moroso back at the firewall where I need room to get the spring compressed. On a stock front end car with inner fenders and roll bar tubing the Moroso definatley has its place for me and the handle can be rotated to pull away from the firewall and master cylinder. If I had a chassis car, and removable front end or a dragster the only one I would have would be the Buxton.
JMO and I really don't care what anyone else thinks ............ Laughing
Post  IDT-572 January 29th 2011, 11:19 pm
If you get the pro form, you can heat it the foot to a dull red and then quench it in used engine oil and it won't bend............... Cool
Post  jbozzelle January 30th 2011, 12:26 am
Moroso here. Works fine with the big springs.
