Engine gurus >>>>> ????????
I still have a short block for sale that has dome pistons that were profiled for the old style AR Cobra Jet cylinder heads. I have someone interested but he just purchased a new set of SCJ-B's. Will these new heads work with the old style pistons?? Or has the combustion chamber been moved or changed enough that they wont??
Travis
Travis
TravisRice- BBF CONTRIBUTOR
Re: Engine gurus >>>>> ????????
Not a guru but I believe the valves were moved requiring different pistons.
lghting94- Posts : 762
heads
Is that all they will need Lem? Will the domes interfer with the combustion chamber at all or just put new valve relifs in them and I'd be good to go? thanks Joe
torinojoe1971- Posts : 19
The DOME's on the older pistons are in a completely different location than what the SCJ chamber shape needs which is also different from the P-51 cumbustion chamber; (although the valves on the P-51's are in the same location as the SCJ's.)
The DOME's will NOT interchange.
» 7.3 gurus
» Any carb gurus here?
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» Question for carb gurus
