how much fuel pump is needed
+12
paulie
mustang68mustangs1
56Tbird
cheatham
342g
'65 T-BOLT
simpleman
mudtrucker
16 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: how much fuel pump is needed
mudtrucker wrote:I found some info on aeromotives web sit. It says that a N/A engines will consume between .4 to 5lbs of fuel per horsepower and a nitrous fed engine will consume .6 to .6lbs per hour and a gallon of fuel weighs 6lbs. So 750X.5= 375/6= 62.5 gph. Thanks for all you input.
Im no expert, but if I remember correctly, when you cross the 700 horse threshold, you want to jump up to the 250gph pumps. 62gph isnt gunna cut it for 700 horses
I run the mallory 250... so far so good
Shane
TorinoGT- Posts : 174
Page 2 of 2 • 1, 2
» Fuel pump in trunk? A2000 opinions and pics needed
» Do I need to remove my already intalled fuel pump eccentric if I'm now going to be using an electric fuel pump?
» Fuel Inj. Pump - Ron's Black Gear Pump - Size "0" - SOLD !!
» BG 400 fuel pump
» early model fuel injected help needed
» BG 400 fuel pump
Page 2 of 2
