89 Bronco 460/ZF swap
FORDMUD
Dr.Ford
crazed
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Thought I would post up what I have been up to.
This is the "Street Truck", it is my '89 XLT, It started life as a 5.0/aod
I did a 6" superlift TTB lift
Did a 351 swap, mass air
D44 SAS
9" rear
I have never been happy with the 351/aod, I get crap mileage, and It was just time for a change for me.
I picked up this truck
It has a 460 EFI and a ZF 5 speed.
I will post lots of pics as I go along.
D44 SAS
9" rear
crazed- Posts : 63
Re: 89 Bronco 460/ZF swap
Last shots before the bronco comes apart
Started pulling stuff off,
And some more
Almost ready to pull the motor and tranny
And some more
crazed- Posts : 63
More teardown,
got the radiator out with the fan,
Pulled the 3G alternator and the hoses
Then, of course cause its Oregon, It started raining
I crawled under and pulled the drivelines and the t-case
Done for the day
Done for the day
crazed- Posts : 63
Motor came out today
On the floor
Now to deal with this mess
Engine compartment harness came out because it is modified for mass air and I figure it should be easier to just use the F250 harness
On the floor
crazed- Posts : 63
Cleaning up
Removed all the red looms off what is left
Ready to start on the F250
Looks a little high in front
crazed- Posts : 63
I found a nest in the air intake of the F250
Then I proceeded to pull the engine compartment wiring harness
crazed- Posts : 63
What is this? it is up by the horns..
More pics
More pics
crazed- Posts : 63
Cleaned up the fender mounted TFI and put it in, (fender had holes for it already)
Swapped computers
Installed the f250 harness
Only one plug didn't match. I'll chase it down when I get underneath
Swapped computers
crazed- Posts : 63
More teardown of the '91 F250
crazed- Posts : 63
Ghetto stuff I found
Shut down for that night
crazed- Posts : 63
I will be using the f250 frame standoffs, and factory F250 mounts.
I was pulling the upper intake off, and bumped the broom handle i was using to prop up the hood. Of course then the 75 pound hood crashes into the back of my head full force and shoves my forehead into the very exposed and very metal water pump. 3 nice dents in my head, and one of them was bleeding pretty good.
This is after some cleanup from my girlfriend.
Hurt a bit, but back at it.
Hood off.
Clean in the valley, no sludge at all
coming out
Did some firewall damage, but I didnt care at this point. Motor did not come out easy with the zf5 attached. I am pretty sure I will install them seperately in the bronco.
Its on the floor with the 351. If you look closely there are 7 engines total in that area. :doh0715:
Hood off.
coming out
crazed- Posts : 63
Got the motor mount standoffs off of the f250
crazed- Posts : 63
Couple more teardown pics
crazed- Posts : 63
Got the ZF5 off, and got the 460 up on a stand so I can get it freshened up
:p
:p
crazed- Posts : 63
Pulled the exhaust manifolds off, One bolt was broken, I broke 3 more.
Took the oil cooler off
Got the ZF5 up on another engine stand
crazed- Posts : 63
This thing had a one piece gasket on it, which I find odd. Tells me it has been apart recently.
Casting number is pretty sloppy
Cover off
And broke!
Cover off
And broke!
crazed- Posts : 63
Guy showed up to get rid of the f250, this was fun!!
crazed- Posts : 63
sad f250 pics
Driveway is clear at least.
crazed- Posts : 63
Tearing down the 460
crazed- Posts : 63
Heads coming off
crazed- Posts : 63
Wear on the sides of the pistons
Wear in the rod bearings
Pistons all out
Crankshaft looks pretty good
Pistons all out
crazed- Posts : 63
Main bearing wear..notice the #1 journal wear is toward the top, and all others the bottom
Lots of casting flash in the valley
And a big chunk of goo on the front of the block and near the 2 rear most lifter bores
Cleaned up
Ready to go get cleaned out and inspected...
Cleaned up
crazed- Posts : 63
Loaded up the 460 for a trip to Don's machine shop in gresham, Just the short block to start with.
crazed- Posts : 63
got my cam,
http://www.summitracing.com/parts/CCA-34-255-5/
teflon seals
http://www.summitracing.com/parts/CCA-503-16/
locks
http://www.summitracing.com/parts/CCA-611-16/
retainers
http://www.summitracing.com/parts/CCA-747-16/
valve springs
http://www.summitracing.com/parts/CCA-926-16/
and a new crank dampner
http://www.summitracing.com/parts/PFS-80008/
teflon seals
locks
retainers
valve springs
crazed- Posts : 63
» 562 possible cam swap
» Intake is shipped
» BB swap 67 Mustang
» Trying to do 460 into thunderbird sc
» WTB fox swap
» Intake is shipped
» WTB fox swap
Page 1 of 3
