89 Bronco 460/ZF swap
FORDMUD
Dr.Ford
crazed
89 Bronco 460/ZF swap - Page 2 Empty Re: 89 Bronco 460/ZF swap
Post  crazed January 29th 2011, 3:44 pm
Machine shop is boring .030, and we are using silv-o-lite pistons, brass freeze plugs, and they are putting in arp rod bolts. Waiting now while they balance everything
crazed
crazed
Post  crazed January 29th 2011, 3:45 pm
Ordered more stuff
http://www.summitracing.com/parts/ARP-150-6902/ FORD HEX OIL PUMP BOLT KIT
http://www.summitracing.com/parts/ARP-154-7005/ STUD KIT
http://www.summitracing.com/parts/ARP-154-7903/ BBF OIL PUMP DRIVE SHAFT KIT
http://www.summitracing.com/parts/FMS-M-6268-A460/ CHAIN & SPROCKET SET
http://www.summitracing.com/parts/FMS-M-6675-A460/ 460 FOX OIL PAN KIT
http://www.summitracing.com/parts/MEL-M84DHV/ OIL PUMP HI-VOL 429/460 TRUCKS
http://www.summitracing.com/parts/PIO-500460/ TIMING CHAIN COVER
crazed
crazed
Post  crazed January 29th 2011, 3:46 pm
Picked up the engine last night, the wife helped me get the block out of the jeep, (she loves that)
89 Bronco 460/ZF swap - Page 2 460-swap-301
89 Bronco 460/ZF swap - Page 2 460-swap-303
They cleaned up the valve covers
89 Bronco 460/ZF swap - Page 2 460-swap-305
Pistons installed on the rods, rods resized and arp bolts in them
89 Bronco 460/ZF swap - Page 2 460-swap-306
Crank looks shiny, .010-.010
89 Bronco 460/ZF swap - Page 2 460-swap-313
89 Bronco 460/ZF swap - Page 2 460-swap-314
Block all clean, Brass plugs, line bore checked out, .030 bore
89 Bronco 460/ZF swap - Page 2 460-swap-315
89 Bronco 460/ZF swap - Page 2 460-swap-316
89 Bronco 460/ZF swap - Page 2 460-swap-317
crazed
crazed
top side
89 Bronco 460/ZF swap - Page 2 460-swap-318
89 Bronco 460/ZF swap - Page 2 460-swap-319
89 Bronco 460/ZF swap - Page 2 460-swap-320
Heads back with comp cams springs, keepers, locks, and teflon seals
89 Bronco 460/ZF swap - Page 2 460-swap-321
89 Bronco 460/ZF swap - Page 2 460-swap-322
89 Bronco 460/ZF swap - Page 2 460-swap-324
89 Bronco 460/ZF swap - Page 2 460-swap-325
crazed
crazed
Post  crazed January 29th 2011, 3:47 pm
Ordered more bolts to put this thing together
ARP-255-1001
Cam Bolt, Pro Series, Black Oxide, 3/8 in.-16 Thread, Ford, Each
ARP-255-3701
Cylinder Head Bolts, Pro Series, 12-Point Head, Ford, 429, 460, Kit
ARP-555-9701
Engine and Accessory Fasteners, Black Oxide, 12-Point, Ford, 429, 460, Kit
And my lifters
CCA-832-16
Lifters, Hydraulic Flat Tappet, Ford, Lincoln, Mercury, Set of 16
crazed
crazed
Post  schmitty January 29th 2011, 9:07 pm
Shocked Busy little beaver there. Very Happy
Post  crazed January 30th 2011, 6:10 pm
Red.
89 Bronco 460/ZF swap - Page 2 460-swap-326
89 Bronco 460/ZF swap - Page 2 460-swap-327
crazed
crazed
Post  crazed January 31st 2011, 1:06 pm
89 Bronco 460/ZF swap - Page 2 460-swap-330
89 Bronco 460/ZF swap - Page 2 460-swap-331
89 Bronco 460/ZF swap - Page 2 460-swap-336
Ready to start putting this thing together
crazed
crazed
Post  crazed February 3rd 2011, 11:42 pm
Shiny new bearings
89 Bronco 460/ZF swap - Page 2 460-swap-339
Crank in and torqued
89 Bronco 460/ZF swap - Page 2 460-swap-342
The pistons I used
89 Bronco 460/ZF swap - Page 2 460-swap-350
Pistons in
89 Bronco 460/ZF swap - Page 2 460-swap-353
Comp cam in, and FMS double roller chain
89 Bronco 460/ZF swap - Page 2 460-swap-360
Checking fit of the new front cover
89 Bronco 460/ZF swap - Page 2 460-swap-367
Lil paint for the top of the block
89 Bronco 460/ZF swap - Page 2 460-swap-368
89 Bronco 460/ZF swap - Page 2 460-swap-369
crazed
crazed
Post  crazed February 7th 2011, 9:19 am
Felpro perma torque gaskets
89 Bronco 460/ZF swap - Page 2 460-swap-370
Heads in place
89 Bronco 460/ZF swap - Page 2 460-swap-371
Arp head bolts
89 Bronco 460/ZF swap - Page 2 460-swap-372
89 Bronco 460/ZF swap - Page 2 460-swap-373
lookin good
89 Bronco 460/ZF swap - Page 2 460-swap-375
My wife doing initial torque
89 Bronco 460/ZF swap - Page 2 460-swap-377
My turn
89 Bronco 460/ZF swap - Page 2 460-swap-380
Yay!!
89 Bronco 460/ZF swap - Page 2 460-swap-383
crazed
crazed
Post  schmitty February 7th 2011, 9:27 am
Tag team torque wrenching. Laughing My youngest sister would love to come help me assemble engines. She knows more about engines than most guys ever will, and it must have been a good thing, she's a Physicians Assistant now, and puts people back together. Hopefully without a torque wrench though. Laughing
Post  crazed February 7th 2011, 10:40 am
Whats funny is my daughter was the one that always came out to watch oil changes instead of my son
crazed
crazed
Post  Dr.Ford February 7th 2011, 8:17 pm
Girls are always curious.
Nice build man. Got a 1990 Bronco but it has a 300/5speed in it. Was thinking about doing a 7.3L swap but lol...naw.
Dr.Ford
Dr.Ford
Post  crazed February 11th 2011, 6:46 pm
Test fitting the edelbrock waterpump and arp bolts
89 Bronco 460/ZF swap - Page 2 460-swap-384
89 Bronco 460/ZF swap - Page 2 460-swap-385
And the fuel pump block off
89 Bronco 460/ZF swap - Page 2 460-swap-386
And another couple coats of red paint
89 Bronco 460/ZF swap - Page 2 460-swap-387
89 Bronco 460/ZF swap - Page 2 460-swap-388
89 Bronco 460/ZF swap - Page 2 460-swap-389
89 Bronco 460/ZF swap - Page 2 460-swap-390
crazed
crazed
Tapped out the dipstick hole in the front cover that I will not be using,
89 Bronco 460/ZF swap - Page 2 460-swap-392
And plugged it
89 Bronco 460/ZF swap - Page 2 460-swap-400
Timing cover, water pump, and counterbalance on
89 Bronco 460/ZF swap - Page 2 460-swap-406
89 Bronco 460/ZF swap - Page 2 460-swap-407
Oilpump shaft is a hd unit from arp
89 Bronco 460/ZF swap - Page 2 460-swap-408
Melling hv pump and the pickup that came with the FMS oilpan set. I used arp bolts on this too
89 Bronco 460/ZF swap - Page 2 460-swap-409
Oilpan on with the factory stiffners and arp 12point bolts
89 Bronco 460/ZF swap - Page 2 460-swap-413
89 Bronco 460/ZF swap - Page 2 460-swap-414
Painted the valve covers
89 Bronco 460/ZF swap - Page 2 460-swap-418
Black wrinkle paint
89 Bronco 460/ZF swap - Page 2 460-swap-421
crazed
crazed
Post  crazed February 16th 2011, 11:11 am
Clutch should be here today
http://www.summitracing.com/parts/ZZZ-MU2001-1/
I got this oil filter bypass adapter the other day..
http://www.summitracing.com/parts/EAR-1178ERL/
I decided that I dont like it, and ordered this instead..
http://www.summitracing.com/parts/CTR-22-595/
I ordered my headers ordered as well..
http://www.summitracing.com/parts/HED-89468/
crazed
crazed
Post  crazed February 18th 2011, 3:29 pm
Lifters installed
89 Bronco 460/ZF swap - Page 2 460-swap-427
Rocker arms and new pushrods
89 Bronco 460/ZF swap - Page 2 460-swap-430
89 Bronco 460/ZF swap - Page 2 460-swap-431
Set the intake on so I can measure bolt lengths..going all arp 12 point...what a pain.
89 Bronco 460/ZF swap - Page 2 460-swap-434
Checking the upper intake, the egr, iac, water neck and the alt bracket..
89 Bronco 460/ZF swap - Page 2 460-swap-435
3G fits right on, think I'll clean up the bracket and remove the air pump
89 Bronco 460/ZF swap - Page 2 460-swap-436
Ordered a bunch of fasteners...I need to mock up the sag swap next
crazed
crazed
Post  crazed February 21st 2011, 9:42 am
Will a 3" single exhaust be enough for this? I still have to pass emissions testing.
crazed
crazed
Post  crazed February 23rd 2011, 11:17 am
I worked on my alt bracket a little, cleaned it up where the air pump used to go, I'll get it sandblasted before I put it on
89 Bronco 460/ZF swap - Page 2 460-swap-437
89 Bronco 460/ZF swap - Page 2 460-swap-440
89 Bronco 460/ZF swap - Page 2 460-swap-441
89 Bronco 460/ZF swap - Page 2 460-swap-442
89 Bronco 460/ZF swap - Page 2 460-swap-443
89 Bronco 460/ZF swap - Page 2 460-swap-445
Other than removing the air pump, the 3G fits right on with no mods at all.
crazed
crazed
Post  FORDMUD February 23rd 2011, 11:45 am
What is the alt bracket originally from? Are they hard to find?
FORDMUD
FORDMUD
Post  crazed February 23rd 2011, 1:10 pm
It was from the '91 f250 donor, I dont think they are hard to find, I just wanted to take the air pump mounts off so it looks cleaner and dosent obstruct the timing marks as much
crazed
crazed
Post  schmitty February 23rd 2011, 3:15 pm
The single 3" exhaust will probably be alright considering this is a low rpm, driver deal. More would of course be better, but if you can't pass the emissions test what good would it do. Cool
Post  Tony M February 23rd 2011, 5:18 pm
Nice build. love the photos and the detail.
Tony M
Tony M
Post  crazed February 24th 2011, 11:10 am
Got the intake installed
89 Bronco 460/ZF swap - Page 2 460-swap-446
89 Bronco 460/ZF swap - Page 2 460-swap-447
Threw the valve covers on just to see what they are gonna look like
89 Bronco 460/ZF swap - Page 2 460-swap-448
89 Bronco 460/ZF swap - Page 2 460-swap-449
The upper and fuel rails just to check bolt lengths
89 Bronco 460/ZF swap - Page 2 460-swap-452
89 Bronco 460/ZF swap - Page 2 460-swap-453
89 Bronco 460/ZF swap - Page 2 460-swap-454
89 Bronco 460/ZF swap - Page 2 460-swap-455
And I ordered this
89 Bronco 460/ZF swap - Page 2 Bbk-3502
http://www.summitracing.com/parts/BBK-3502/
crazed
crazed
Post  crazed February 27th 2011, 9:58 pm
Found a van with a efi 460
89 Bronco 460/ZF swap - Page 2 460-swap-464
There is the sag bracket we need
89 Bronco 460/ZF swap - Page 2 460-swap-467
And its out, I don't need hoses or anything because I had a Saginaw swap on my 351
89 Bronco 460/ZF swap - Page 2 460-swap-468
Got the wife/helper to carry it out
89 Bronco 460/ZF swap - Page 2 460-swap-470
And it's home
89 Bronco 460/ZF swap - Page 2 460-swap-472
crazed
crazed
