Engine Diapers?
+12
stangr8cr
BigDave65
56Tbird
Barney
powerstrokeace
342g
Treeyasoon
Tony M
jcoxracing
16 posters
Engine Diapers?
What brand of engine diapers are you all using? How hard is it to take the engine diapers on/off to change your oil?
Thanks for your time
Justin
Justin
jcoxracing- Posts : 282
Re: Engine Diapers?
Stroud. 7.2 Sfi. Just drop the front strap and pull back a couple of inches and expose your oil filter then push the bottom back and expose the drail plug for you guys with the wet sump. At the worst it adds 10 mins to your oil change.
Tony M- Posts : 479
Re: Engine Diapers?
invisible kind here......I will be adding a pan though.
Re: Engine Diapers?
I have a DRE on mine...nice quality piece and Dennis was good to deal with. Fit is ok on mine but, I had a custom piece made and, if I would have known then what I know now, I would have changed a few things....nothing they did wrong though. Like Thunderstruck said, it doesn't add much time to your oil change, once you get used to it.
Treeyasoon- Posts : 759
Re: Engine Diapers?
Dre also with fire proof sides for header clearance, mine were special made, but this year I see they are offering them.
342g- BBF CONTRIBUTOR
Re: Engine Diapers?
DRE's on both cars.. Dennis is a great guy yto work with
Ace
Ace
powerstrokeace- Posts : 1496
Re: Engine Diapers?
Champion on mine with an external wet sump. It's off in a couple of minutes. No problem.
56Tbird- BBF CONTRIBUTOR
Re: Engine Diapers?
I just put a Champion on mine also. Fits nice
BigDave65- Posts : 567
Re: Engine Diapers?
DRE on mine also. The fit and amount of trouble has alot to do w/chassis. Mine is about as easy as it gets,because it's all wide open underneath. (Non) chassis cars w/shock towers are alot more difficult.
Re: Engine Diapers?
DRE here in a non tube chassis fox. About as easy and nice a fit you can get with the limited space. Like has been said, 10-15 minutes added for oil changes.
Boo Boo
Boo Boo
stangr8cr- BBF CONTRIBUTOR
Re: Engine Diapers?
stangr8cr wrote:DRE here in a non tube chassis fox. About as easy and nice a fit you can get with the limited space. Like has been said, 10-15 minutes added for oil changes.
Boo Boo
team Sherry has about the nicest diaper i have seen ... but i believe it was a one off deal
i went with the pan deal
Re: Engine Diapers?
Can you send me some pics off the pan Nick? We may try to go that route with the new engine. If its too much trouble, we may just get another DRE made up. How do you like it over a diaper?
Boo Boo
Boo Boo
Re: Engine Diapers?
I have used DRE and Stroud in the past. I loved the fit and ease of install/removal of the DRE. I had the Stroud on when I push a rod out of the block. It contained all of the parts until I got to the shut of road and then a rod cap melted thru the side. But, it did not drop any oil on the track or allow any on the rear wheels at 180mph. :/
I am going with a carbon fiber pan for the dry sump set up.
Curt- Posts : 2791
Re: Engine Diapers?
I guess I have to have one for the street bracket at my local tracks major event, don't know what I'm gonna do about that. May just get a cheap one to pass tech, if it were a full on race car I would understand and I would get a good one. But not for this!
bb429power- Posts : 3129
Re: Engine Diapers?
Thanks for all of the replies. I think I will give Dennis a call for one of those customs diapers, because I have very little room between the pan and steering linkage/crossbar.
Justin
Justin
Re: Engine Diapers?
Curt wrote:I have used DRE and Stroud in the past. I loved the fit and ease of install/removal of the DRE. I had the Stroud on when I push a rod out of the block. It contained all of the parts until I got to the shut of road and then a rod cap melted thru the side. But, it did not drop any oil on the track or allow any on the rear wheels at 180mph. :/
I take it you did'nt have the liner in it when the rod burn't through it. Mine has a fireproof liner.
Re: Engine Diapers?
bbf-falcon wrote:Curt wrote:I have used DRE and Stroud in the past. I loved the fit and ease of install/removal of the DRE. I had the Stroud on when I push a rod out of the block. It contained all of the parts until I got to the shut of road and then a rod cap melted thru the side. But, it did not drop any oil on the track or allow any on the rear wheels at 180mph. :/
The liners don't cover the sides, when mine came apart, I thought I had top end problems, ntil it set for a week, I looked under it and the oil was barely coming through, nothing on track return road, dre is a good product, I.M.O.
Re: Engine Diapers?
Installed as per Stroud instructions. Harold is right, the cap melted through the side.
Curt- Posts : 2791
Re: Engine Diapers?
You cheap ass's I bought a bunch of the fire proof absorbent and put velcro on the sides too keep it in place.
Re: Engine Diapers?
Speaking of cheap ass, have you seen my girlfriend, thats cheap.
Oh yea, if any of you guys plan racing Kil-Kare this year, anything faster than 6.39 in 1/8, 6.99 1/4, must have a diaper.
Re: Engine Diapers?
richter69 wrote:invisible kind here......I will be adding a pan though.
and to think, you gave me a hard time because we didn't have anything last year.
whatbumper- Posts : 3024
Re: Engine Diapers?
I just gave you a hard time about the zip ties..........but they were the industrial size so i let it slide...............
Re: Engine Diapers?
richter69 wrote:I just gave you a hard time about the zip ties..........but they were the industrial size so i let it slide...............
only the best for our turd.
you forgot about the hose clamps holding the extra ballast on. adding 150+ lbs for one race was hell.
» Engine Diapers
» Engine diapers
» Does anyone have pics of their engine diapers installed?
» Engine Masters 534 Boss Engine and BBF 72 Torino in the new PHR Magazine.
» Engine diapers
