Nitrous limit ??
+12
460Dave
Barney
Buddy Thomas
gryphon68
JoeH_88
Induction-Solutions
Old blue Racin Team
Greg_P
studly
16 posters
Nitrous limit ?? Empty Nitrous limit ??
Post  bruno September 2nd 2009, 5:21 am
so what are the limiting factors on how much nos you can put to a motor ?? is it cubic inches ? cam? intake volume of heads ?? can anyone elaborate on this one
http://WWW.CKRME.COM
Nitrous limit ?? Empty Re: Nitrous limit ??
Post  studly September 2nd 2009, 7:30 am
I do not think there is a set limit, I think each motor is different and based on all the factors you mentioned. i have seen as much as 400 plus on a 306 sbf 40 nos pill fogger, the guy kept spraying until it finally give up, there is a guy that runs a BBC in the Rengade class at Piedmont NC he sprays a 36 jet in both foggers. as long as it runs faster you keep spraying and keep tunning just hope you have money for parts.
studly
studly
Post  Greg_P September 2nd 2009, 10:46 am
I have heard the limit explained like this:
One size smaller jet than the one that just caused your junk to grenade.....
Greg_P
Greg_P
Post  Old blue Racin Team September 2nd 2009, 10:55 am
Greg_P wrote:I have heard the limit explained like this:
Yup and how ever much you as the driver can handle
My uncle is has a 500 shot, and is putting 2 more 300 on it, but it is a 636 Profiller motor
Old blue Racin Team
Old blue Racin Team
Post  Induction-Solutions September 2nd 2009, 11:39 am
To me the limit is somewhat decided by the engines components... Block, crank, rod, pistons and so on.... The nitrous system being properly set up and tuned has a lot to do with the final output as well as the reliability as well.. Thanks, Steve
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
Post  JoeH_88 November 26th 2009, 9:32 pm
I have a 532 built to take all i can throw at it. How much nitrous can i spray before it stops making power? What determins the limit?
Thanks in advance for any input!
JoeH_88
Post  gryphon68 November 28th 2009, 9:08 pm
JoeH_88 wrote:I have a 532 built to take all i can throw at it. How much nitrous can i spray before it stops making power? What determins the limit?
Assuming the tune is correct, you don't break any parts, and have enough spark to get things lit, the exhaust flow will be the limiting factor as to when it will stop making additional power when more nitrous and fuel is added.
Exhaust flow in this case is more than just cylinder head flow numbers, it includes cam timing, header size, etc.
gryphon68
Post  JoeH_88 December 1st 2009, 7:14 am
How much nitrous have you guys put through a 532?
JoeH_88
Post  bruno December 1st 2009, 1:12 pm
JoeH_88 wrote:How much nitrous have you guys put through a 532?
what heads/cam/etc......... need more details Wink
Post  Buddy Thomas December 4th 2009, 10:29 pm
Most of the time its not what the motor will take but what you can get to the ground. We run a 28/24 jets at 6 1/4 fuel pressure and pull 6 out of the motor. we are able to get it all to the ground. Last weekend we had some 1.05 60' times. Its all in the tune up
Buddy Thomas
Post  Lem Evans December 5th 2009, 12:07 am
bruno wrote:so what are the limiting factors on how much nos you can put to a motor ?? is it cubic inches ? cam? intake volume of heads ?? can anyone elaborate on this one
In one word....budget tongue
Post  Barney December 8th 2009, 10:51 am
Fuel and the mechanical limits of the components.
Barney
Barney
Nitrous limit ?? Empty I would like to
Post  460Dave June 1st 2015, 9:28 am
resurrect this topic please....
Given that there are a large number of variables that play a part in the "how much" question, I would like anyone that has had experience to let me know what they have found with amount of nitrous vs durability.
Do you see any obvious durability challenges in my combo that would restrict more nitrous?
How big can I go without an obvious challenge?
Current combo - 36 jet (about 350 shot)
Dove-A block - filled and 4-bolted w/ CAT splayed caps (stock bolts, studs where the windage tray is)
Lunati forged crank (4.5")
Scat H-beams w/ ARP 2000 bolts
Diamond pistons w/ H13 tool steel wrist pins (.185)
P51 heads w ARP studs (.088 quench - 11.55-1)
Innovative West balancer
2" primaries to 3" full exhaust (I know this is a restriction, but don't know how much) Personal best - 5.40@129.9 w/ 1.26 60' - 3400lbs
460Dave
Post  68formalGT June 1st 2015, 1:39 pm
Buddy Thomas wrote: Last weekend we had some 1.05 60' times.
That's getting it!! that would make an awesome mud truck engine where we only run 100-150 feet. What's the whole combo consist of?
Post  gmsmkr June 2nd 2015, 10:50 am
460Dave wrote:resurrect this topic please....
The only thing I see as of restrictions is the 2000 rod bolts (I would replace with new if they have a good amount of pass on them) and 2" primary headers with full exhaust.... IMO the 2" primaries are good to about 500 then they slowly start to be restrictions.
Also the thickness of the piston top also has alot of play in more nitrous ( first ring land to top of piston)
gmsmkr
gmsmkr
Post  whatbumper June 3rd 2015, 5:37 pm
As stated above: header size, camshaft, quench distance, ring placement, and over all parts quality.
Camshaft is a huge deal. We have some guys spraying huge amounts on large cubic inch motors and its hard to even grasp some of the numbers we put in a cam. Not even comparable to small motors (under 588).
You will get to a point that adding more nitrous will not net you anything. Crazy as it sounds.
Post  Larry T June 3rd 2015, 8:48 pm
their is a formula that the nos gurus use I don't know what it is but I have an idea.cubic in X jet size or jet size verses cubic in not sure.
Larry T
Larry T
Post  Lem Evans June 3rd 2015, 10:45 pm
With big shots....pulling enough timing is the biggest deal.
Post  richter69 June 3rd 2015, 11:01 pm
Sho nuff .... ^^^^
