8.8 Posi issues
frank13
bb429power
8.8 Posi issues Empty 8.8 Posi issues
Post  bb429power February 12th 2011, 4:35 pm
The mav. has an 8.8 posi unit and its staying that way for right now. Sometimes when I'm in the burnout box (usually where it happens, very seldomly does it do this on the street) it will do a one wheel peel. Any idea what causes this? Could it be the fluid level or the fluid itself? What's an easy fix for this if there is one?
bb429power
bb429power
8.8 Posi issues Empty Re: 8.8 Posi issues
Post  frank13 February 12th 2011, 4:41 pm
bb429power wrote:The mav. has an 8.8 posi unit and its staying that way for right now. Sometimes when I'm in the burnout box (usually where it happens, very seldomly does it do this on the street) it will do a one wheel peel. Any idea what causes this? Could it be the fluid level or the fluid itself? What's an easy fix for this if there is one?
have you rebuilt it ever, prob a combo of the oil and clutches,
frank13
frank13
http://www.frankskinkracing.com
Post  bb429power February 12th 2011, 4:48 pm
I haven't, but the previous owner said he put it in. It was fine but then it started acting up more recently, I haven't checked the fluid yet. In storage at grandparents house, but I do want to check it. Is there a special additive or rear end dope to put in it like a LSD style axle?
bb429power
bb429power
Post  whatbumper February 12th 2011, 11:29 pm
time for a rebuild. you can buy factory Ford additive at the dealership
Post  DFI429 February 13th 2011, 12:20 am
Justin, the 8.8 takes the usual gear oil and a friction modifier, or a pre-mix of both. If it's not too old a fresh change may help.
DFI429
DFI429
Post  4thHorseman February 13th 2011, 10:31 am
If you are mostly drag racing the car you might want to have the rebuilder set it up real tight by shimming it. I added shims to my wife's Roush's 8.8 when I swapped in 4.10's. That's about the best you can do for a trac lok it this application.
4thHorseman
4thHorseman
Post  bb429power February 13th 2011, 11:29 am
Mainly it is on the street in the summer, I do take it to the track twice a year Embarassed But I want to go more often. Later down the road this thing is going to be TOTALLY reformed in to the baddest drag car around these parts Twisted Evil But until then, I don't think I'll rebuild the 3rd member just yet. Soon when I can get it back in my own garage or when its warmer at least, I want to check the fluid. Maybe pull it apart and completely refill it. Depending on the cost I could rebuild it while its apart, just curios what would cause this so I can plan another project. Laughing
Thanks guys, I will take in to consideration all of the things said above. Very Happy
bb429power
bb429power
Post  BOSS 429 February 13th 2011, 1:14 pm
needs rebuilt, it is an 8.8, and not a factory 8''?
Post  bb429power February 13th 2011, 10:08 pm
8.8 Smile
bb429power
bb429power
