A-460 head / plugs??
scottke
Hope to fire the new bullitt soon, it has motorsport A460 heads. What is the best plug # to run for now NA?
scottke- Posts : 970
Re: A-460 head / plugs??
Autolite Racing #AR3934.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Thanks Charlie, didn't figure the same plugs in my SCJ heads would work. Didn't even cross my mind to try actually. lol
X2c.evans wrote:Autolite Racing #AR3934.
Charlie
I feel kinda dumb Rick.
scottke wrote:I feel kinda dumb Rick.
Don't feel bad, I feel like that each and everyday
scottke wrote:Hope to fire the new bullitt soon, it has motorsport A460 heads. What is the best plug # to run for now NA?
I never got help on the last one...............
Anytime you want to put some snake jelly on this new one, you are more than welcome to. LOL
If you had touched the other one, I prolly would have got into the 9's. LOL
i realy like the ngk plugs,not sure about the # but i can look.
Check if you don't care, I can try both.
R5671A-8........i run alky.the last #[-8] is the heat range.on gas i'm not sure what you'd want.i've had good luck with them.
Thanks, I'll have to check them out.
cool40 wrote:R5671A-8........i run alky.the last #[-8] is the heat range.on gas i'm not sure what you'd want.i've had good luck with them.
That is the same heat range as the AR3924. The autolight plugs will get lower in number as they get colder and the NGK will get higher in numbers as they get colder. I run one heat range colder with alcohol.
Curt- Posts : 2791
» A-HEAD 598 SPARK PLUGS
» freeze plugs in head
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» coolant leak between head and block at head bolt location.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
