Too much gear? Not enough converter?
D. Sea
Race Ready Fabrications
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Too much gear? Not enough converter?
The 4.10 gear will make the converter stall higher at the flash.
Get your converter above 5500 on the brake and put your 4.10 gear in it, and report back. An 8 inch will probably suit your deal better.
We shall find out April 9th. She will either go or blow
Race Ready Fabrications- Posts : 619
IDT-572 wrote:Get your converter above 5500 on the brake and put your 4.10 gear in it, and report back. An 8 inch will probably suit your deal better.
X2
Page 2 of 2 • 1, 2
» Pro Stock Trans gear ratio / Rear Gear
» New Ultimate Converter Concepts Converter Test Results-Updated
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
Page 2 of 2
