Alternator Question
Tore
Alternator Question Empty Alternator Question
Post  Tore March 24th 2011, 7:16 am
I installed an alternator in my car. All the wiring was in place and its also got a Painless Charging system relay.
I hooked the wire to the alt. and never tested it. I went in the house and came back out the next day and the alt. was warm. I have no idea why. I checked the wiring diagram for the relay and its wired correctly. The alt is a mini 1 wire alt. I never tested the alt to see if it was charging when it was running. I just unhooked it. Any ideas??
Thanks Tore
Tore
Tore
Alternator Question Empty Re: Alternator Question
Post  res0rli9 March 24th 2011, 7:37 am
Thats one hot Alt. you got Smile
Post  PROSTREET66 March 24th 2011, 10:27 am
did you check the Flux Capacitor??????
PROSTREET66
PROSTREET66
Post  '65 T-BOLT March 24th 2011, 10:33 am
all your grounds good?
'65 T-BOLT
'65 T-BOLT
Post  bbf-falcon March 24th 2011, 10:36 am
Tore,I would call the alt. mfg. Smile
Post  Bigshank March 24th 2011, 11:04 am
mike has a master switch on his mustang (4 post) his alt doesn't get hot. you have to put put 8gauge on the (on) side to alt on one of the post and the other gets battery cable if not mistaking.
Bigshank
Bigshank
Post  Tore March 24th 2011, 12:18 pm
PROSTREET66 wrote:did you check the Flux Capacitor??????
Whats that?
Tore
Tore
Post  Tore March 24th 2011, 12:19 pm
bbf-falcon wrote:Tore,I would call the alt. mfg. Smile
I bought it off ebay, I don't remember any names on it.I might take and have it checked out. Its internally regulated.
Tore
Tore
Post  Tore March 24th 2011, 12:22 pm
The car came prewired as you can see an alt was there before. I have the schematic and traced all the wires and everything looks good. Otherwise to test things out I will run a wire outside the car to the post by the solenoid where the hot side comes and see if it gets warm that way.
Tore
Bigshank wrote:mike has a master switch on his mustang (4 post) his alt doesn't get hot. you have to put put 8gauge on the (on) side to alt on one of the post and the other gets battery cable if not mistaking.
Tore
Tore
Post  Tore March 24th 2011, 12:23 pm
'65 T-BOLT wrote:all your grounds good?
yes
Tore
Tore
