Destroyed Engine in Lighting
83-88T-Bird Guy
bigblockfox468
Tennessee Bullitt
Destroyed Engine in Lighting Empty Destroyed Engine in Lighting
Post  Tennessee Bullitt March 25th 2011, 8:18 pm
Well going to town today I went to get on it a little and pop. Evil or Very Mad Pulled in Mcdonalds and went to look and I have a hole on each side of the engine block at the rear of the motor. It's weird because I drove 1 1/2 miles before I shut it off. I guess I am going to start getting ideas for a 460 build to replace this one. Twisted Evil
Tennessee Bullitt
Tennessee Bullitt
Destroyed Engine in Lighting Empty Re: Destroyed Engine in Lighting
Post  bigblockfox468 March 25th 2011, 9:09 pm
HUH...... scratch
bigblockfox468
bigblockfox468
Post  cool40 March 25th 2011, 10:08 pm
thats gotta suck! how many miles on it?
Post  IDT-572 March 26th 2011, 12:06 am
Gen one or gen two?
Post  Tennessee Bullitt March 26th 2011, 9:51 am
Just over 86,000. It's gen 2 just like your Blake. Even the same color Very Happy I found out this morning it had to do with the rod bolts. The holes in the block are perfect round size of rod bolts. I am still learning on this one.
Well atleast my drum of fuel came in so I still have the mustang to get around town. cheers
Blake what do you think of putting a 460 in place of this 5.4?
Tennessee Bullitt
Tennessee Bullitt
Post  IDT-572 March 26th 2011, 10:04 am
I think you will be hard pressed to get the same power from the 460 and still get the fuel mileage of the blown 5.4 , but the big block would be fun and cool in that truck, I think the handling may suffer also.
Post  Tennessee Bullitt March 26th 2011, 12:01 pm
Didn't Lem do a 502 motor that had awsome results? I am looking at cost... seems the 460 would be cheaper to build than a 5.4. I am still looking at all options.
Tennessee Bullitt
Tennessee Bullitt
Post  83-88T-Bird Guy March 26th 2011, 7:58 pm
Has anyone came up with a kit to put a 460 in a 97-03 F-150 ?
I am now seeing those trucks showing up at reasonable prices.
83-88T-Bird Guy
83-88T-Bird Guy
Post  cool40 March 26th 2011, 8:39 pm
with a 460 back under the dash you would'nt be f****n with coil packs and broke off plugs. Very Happy
Post  83-88T-Bird Guy March 26th 2011, 9:53 pm
cool40 wrote:with a 460 back under the dash you would'nt be f****n with coil packs and broke off plugs. Very Happy
I got a look under the hood of a '97 F-150 last weekend. Looks like a 460 would clear the firewall o.k.
My brother has a '97 x-cab shortbed 2wd F-150.
It has a 4.6 with engine problems and needs work.
He likes 460 trucks as well, so maybe I can convince him to swap in a 400 hp pump gas 460. Very Happy
83-88T-Bird Guy
83-88T-Bird Guy
Post  cool40 March 26th 2011, 10:16 pm
i'm sure it would clear anywhere a mod motor will go and do a much better job. Laughing
Post  Tennessee Bullitt March 27th 2011, 8:16 am
Hey Alan a 460 will give more room than you think. I have more room in my 03 mustang with motor I built than the previous 4.6's. To give you an idea I am running 2 1/8 headders on a factory 93 k-member with the ford racing swap motor mounts and can move my hands past the frame rails to the k-member easier than I could than the 4.6 with a tublar k-member and 1 3/4 headders. Bolting a 460 in a newer truck will definatly have lots more room because they was built to accept a 5.4 even if it had a 4.6. If that makes any sense.
I agree changing spark plugs especially on a lightning is a major pain. I already have someone calling me wanting to buy my top end off the lightning so we will see.
Tennessee Bullitt
Tennessee Bullitt
Post  lghting94 March 27th 2011, 9:03 pm
I know where there is a 5.4 lightning motor, i am checking on a price.
lghting94
lghting94
Post  lghting94 March 27th 2011, 9:15 pm
check your PM's I have some details
lghting94
lghting94
Post  whitefield March 28th 2011, 11:14 am
The 460 wouldn't give any handeling problems! The weight of the 5.4 with the blower is equel to a cast iron headed 460 and you wouldn't lose much if any fuel mileage . The 5.4 has to run 93 and only about 14 miles to the gallon! As a comparisson a 95 1 ton 4 door dually with 4:10 gears gets 12mpg. So in a 2500 lbs lighter vehicle with 3:55 rear gears and a overdrive trans should be the same as the 5.4 or a little better fuel and performance wise.
Put a fast fuel system on it a set eldelbrock performer heads 9.0:1 compression custom grind Hyd roller with 112 or 114 lobe seperation 24 lb injectors and a AODE trans and let her rip! just My Thoughts on it!
whitefield
whitefield
Post  dfree383 March 28th 2011, 11:16 am
Have a tough time getting past the EPA Man........ But would be cool to do.
Post  IDT-572 March 28th 2011, 12:00 pm
whitefield wrote:The 460 wouldn't give any handeling problems! The weight of the 5.4 with the blower is equel to a cast iron headed 460 and you wouldn't lose much if any fuel mileage . The 5.4 has to run 93 and only about 14 miles to the gallon! As a comparisson a 95 1 ton 4 door dually with 4:10 gears gets 12mpg. So in a 2500 lbs lighter vehicle with 3:55 rear gears and a overdrive trans should be the same as the 5.4 or a little better fuel and performance wise.
Sorry guys I stand corrected Embarassed
Post  D. Sea March 28th 2011, 12:18 pm
dfree383 wrote:Have a tough time getting past the EPA Man........ But would be cool to do.
Wha'ts the EPA thing you speak of? We are in Kentucky foo Razz
D. Sea
D. Sea
Post  Tennessee Bullitt March 28th 2011, 1:10 pm
EPA sucks, I think they would have more of a fit over my stang. Lightning94 might have the hookup for me. I will let ya know what comes out of it.
Tennessee Bullitt
Tennessee Bullitt
Post  dfree383 March 28th 2011, 1:12 pm
Keep talkin....... Cali CARB BS will bit you in the arse sooner of later........ if you want to drive it on the street and register it Shocked Laughing Suspect clown tongue
Post  D. Sea March 28th 2011, 3:11 pm
Bah.... I could tag my car and drive it on the street today if I wished... Title says It's a "79 Mustang" What a Face
D. Sea
D. Sea
