oil seals not staying on the guide
These are on my jegs/kaase canted valve aluminum heads for my cobra 2 and it came with comp cams #503 seals and when i pulled the heads a few nites ago (nitrous was hungry and ate a head gasket last sunday) i noticed only 3 of the 16 were on the guide the rest were riding on the valve stem are they worn out maybe ? they should stay on the guide right ? the springs are comp #924. with a 534 lift flat hyd cam. (292h)
nuclearcobra- BBF CONTRIBUTOR
Re: oil seals not staying on the guide
wrong seals?
The 924 spring calls for a 503 seal, maybe there not 503 seals i thought they were assembled with those. Are u supposed to install the seals dry ? when i did it they had oil on the guide and inside the seal a little. Its says they have amco 45 guides and .531 teflon seals they look like the comp 503 set i have here for another pair of heads.
Measure the guides and seal, they may be the wrong size?
What comp say will work with the spring doesn't matter it the guides have been cut down to a different size.
The guides are .530 and the seals are .505-.506 id the guide # is che 501-e215 i'm gonna try some new ones and install them without oil on them and see what happens
Sounds to me as though the valve spring is oscillating enough for the inner spring to contact the seal.
nuclearcobra wrote:These are on my jegs/kaase canted valve aluminum heads for my cobra 2 and it came with comp cams #503 seals and when i pulled the heads a few nites ago (nitrous was hungry and ate a head gasket last sunday) i noticed only 3 of the 16 were on the guide the rest were riding on the valve stem are they worn out maybe ? they should stay on the guide right ? the springs are comp #924. with a 534 lift flat hyd cam. (292h)
I had the same problem with some scj cylinder heads that have guides that are slick cut where the seal slides down, some heads have guides that look like this http://www.trickflow.com/largeimage.asp?part=TFS-41400251-1 where the seal goes, 503 seals wont stay on the slick cut guides , use these on those, http://www.jegs.com/i/Comp-Cams/249/529-16/10002/-1?parentProductId=1122701
and check what Mr.Randy said
10SHOTS- Posts : 587
I wondered about it moving around too much also,the spring cups are getting changed as well and they might be the problem their the right cups for the springs but as defree pointed out it don't mean there right for the guides, the cups now are cc #4700 .640 id and the ones on the way are .570 id and they fit snug on the guide (just needed 8 more) and if it still does it then i'll try the metal viton seals 10shots is talkin about.
Your right Randy after taking more springs off i can see that the springs have hit the seals because some of the bottom edge of the seals are ripped and hanging there. Its my fault i bought the cups for that spring with no regard for guide size well at least it didn't hurt anything and i had to pull the heads anyway because of the head gaskets which is strange because it didn't burn them, the bottom water holes between the cylinders were missing gasket material and it leaked water into #7 cylinder. I bought the cheapest gasket kit i could find it was 38 bucks i always wanted to know how cheap they really are and it also said maxium compression is 10 to 1 and its 10.5 without the 125 shot.The heads are going back on today with felpro gaskets and the right cups
Everythings good now and no more smoke to boot and i thought it started smoking because the rings were wearning out from the spray (factory bottem end) but not the case
» valve seals
» Fords at the summit, Wheres everyone staying?
» Valve stem seals
» The PI's Showed UP Early
» Seals?
» Valve stem seals
» Seals?
