tfs a460 18 bolt heads
Does anybody know if the new 18 bolt a460 heads would work on a 10 bolt block.
90 lx coupe- Posts : 5
Re: tfs a460 18 bolt heads
Yes they will.......you just can't use the extra 8 bolts. The 10 9/16" holes are in the same position as the production stuff.
thanks90 lx coupe wrote:Does anybody know if the new 18 bolt a460 heads would work on a 10 bolt block.
» question on compression ...using pump gas (a460...using fms a460 heads)
» Question about TFS A460 and Motorsport A460 heads
» questions...TFS 18 bolt A460 heads
» A460 intake bolt kit
