Breakin ? header e-vac system
does it matter if its hooked up or is it better to unhook it for the 1st. 30 minutes during breakin ? i thought i read something about that but it might have been about a vacuum pump ?
nuclearcobra- BBF CONTRIBUTOR
Re: Breakin ? header e-vac system
It;ll be ok...........it's the vacuum pump you gotta worry about. The evac. off idle won't pull much i.m.o. .....or just leave the hose off.
Thanks Lem i'll leave it off then
Or.....put one on and leave one offnuclearcobra wrote:Thanks Lem i'll leave it off then
» Tuning with a wideband O2 sensor
» piston ring choice and preferred ring seat/breakin time ?
» crankcase evac system vs open breathers
» Cooling System - STREET DRIVEN
» Fuel system set up ?
