alcohol motor ring gap
Frank Kramer
johndickjr
alcohol motor ring gap Empty alcohol motor ring gap
Post  johndickjr May 22nd 2011, 3:23 pm
i was told that for a alcohol motor the ring gap needs to be around .011 range...is that true? or just normal gap
johndickjr
alcohol motor ring gap Empty Re: alcohol motor ring gap
Post  Curt May 22nd 2011, 4:11 pm
johndickjr wrote:i was told that for a alcohol motor the ring gap needs to be around .011 range.
Come on John, this is a big block forum. Smile
Post  johndickjr May 22nd 2011, 4:14 pm
ya...and so ?
johndickjr
Post  Frank Kramer May 22nd 2011, 4:23 pm
Contact the ring manufacturer,
It depends on the rings that you are using and the bore diameter....
Frank Kramer
Frank Kramer
http://www.seasideaffair.com
Post  Curt May 22nd 2011, 4:23 pm
Is this gap for a small block racing motor? confused , small CI street motor?
Post  rmcomprandy May 22nd 2011, 6:04 pm
If the ring gap is to be "in the .011" range" then this must be from a 2 3/16" bore motorcycle engine...
Post  DFI429 May 22nd 2011, 6:06 pm
rmcomprandy wrote:If the ring gap is to be "in the .011" range" then this must be from a 2 3/16" bore motorcycle engine...
Or a 55 9/16 MM... Very Happy Wink
DFI429
DFI429
Post  bbf-falcon May 22nd 2011, 7:05 pm
Always read instructions Laughing
Post  johndickjr May 23rd 2011, 7:13 am
i mean should the ring gap be smaller with a alcohol motor is all
johndickjr
Post  res0rli9 May 23rd 2011, 8:14 am
johndickjr wrote:i mean should the ring gap be smaller with a alcohol motor is all
As said! Always read instructions
Post  richter69 May 23rd 2011, 8:26 am
again go by the instructions............ all of um I have done end up being in the same range as a gas deal, in no way would they ever be than small on anything that would power a car lol.
Post  johndickjr May 23rd 2011, 8:47 am
ok..thanks
johndickjr
