Is there a epoxy that would fix a cracked hvh supersucker
i have a 4150 plastic one that cracked between the holes like they do.
nuclearcobra- BBF CONTRIBUTOR
Re: Is there a epoxy that would fix a cracked hvh supersucker
JB Weld works great. I've fixed alot of things in apps where gasoline is involved, and never had an issue.
ThndrChkn- Posts : 2216
Napa sales some plastic repair that works good you might try that it is a 2 part deal i have used it and it works I have used it on a battery where a hole got knocked in it and it helled up good on tje battery to.I would try to V the crack out alittle to get a good bond.
Jim
Jim
nuclearcobra wrote:i have a 4150 plastic one that cracked between the holes like they do.
I wouldn't trust that the plastic would give away after the epoxy fix and end up going through the engine; the aluminum ones don't fracture like that.
If you wish to get the insulating effects then use a genuine phenolic spacer, (not a plastic one).
In my opinion, get a JOMAR "Power Cone".
I'd cut the center out and make an open spacer outof it, then go buy me a powercone...............IMO not worth the risk if it cracks and breaks loose and ends up tearing up an engine over a 90 dollar spacer.
Yea your right Randy it is a chance a big chance maybe i'll just use it for a carb stand i just figured if they epoxy head and intake runners then maybe this could be fixed and if not no big deal i bought it used for 50 bucks.
Yea screw it i'd freak if it killed my motor i have two of the aluminum ones for the 4150 to 4500 carb to try with the 1050 dommy i have but i have a buddys ported aed 950hp 4150 that flows 1020cfm on it now and wanted to try the hvh on that and then compare it to a dominator with a suckersucker.
» HVH SUPERSUCKER 2" DOMINATOR ***SOLD***
» 1050 powercone/supersucker
» cracked head
» A&B Epoxy putty
» Hyper-u-cracked-it Pistons
» cracked head
» A&B Epoxy putty
