cracked head
cracked head
I have a set of dooe r heads,both have a crack between the seats.One is leaking one is not.Is there a real fix for them? I have done some research found a place,said they could fix them.Midwest cylinder head,anybody delt with yhem before,or know someone else,that you trust?
466bronco- Posts : 23
Re: cracked head
I've never delt with them, but yes most of the time simple cracks can be repaired.
» Is there a epoxy that would fix a cracked hvh supersucker
» A460 block with cracked main cap
» Cracked Engine Block
» Hyper-u-cracked-it Pistons
» Distributor shaft cracked
