so im gutting my little 302 for a quick shortblock rebuild.....
Do you guys thing 11.3:1 compression with a zero deck, small dome piston with AFR 185's and a cam with 552/538 lift and 243/257 duration at .050 would be to much for 93?
cam is set in stone as i want to try this big mutha thumpr cam
Re: so im gutting my little 302 for a quick shortblock rebuild.....
i do, but i dont build pump gas deals.someone will tell us.lol
im just wanting to get as much squeeze as i can and still be able to go anywhere without looking for an airport to fill up at
i would step up to afr 205's, set timing at 32 with flat tops would be good for mid 11's or lower
Larry Williams- Posts : 884
i think you can get away with it, my 302 used to have kb hypers with a 200cc dome using world iron heads with 62cc chambers and it was fine which was 10 to 1 compression and smaller cam, your aluminum heads, bigger cam should be fine what is the dome ?
nuclearcobra- BBF CONTRIBUTOR
The ? was would his combo be fine with pump gasLarry Williams wrote:i would step up to afr 205's, set timing at 32 with flat tops would be good for mid 11's or lower
I picked up the 185's for 300 bucks new in box from a guy who cant race anymore. otherwise this 302 wouldnt even get the e7 heads off of it and id just throw it in the car as is
IMO the 185s are plenty big for a 302" motor, the 205's would work good on a full race deal but if you looking for any low end they will be way to big and lazy in a "Street" application. Also don't forget everythng else that will need to go with the Big cam..... Convertor, Gearing Ect.
dfree383 wrote:IMO the 185s are plenty big for a 302" motor, the 205's would work good on a full race deal but if you looking for any low end they will be way to big and lazy in a "Street" application. Also don't forget everythng else that will need to go with the Big cam..... Convertor, Gearing Ect.
thats true about the 205's but boy they work good. I built a 331 with 205's with an old ford la mans cam for the street for a friend it all worked well with pump gas.
my 225's are amazing.
Larry Williams wrote:dfree383 wrote:IMO the 185s are plenty big for a 302" motor, the 205's would work good on a full race deal but if you looking for any low end they will be way to big and lazy in a "Street" application. Also don't forget everythng else that will need to go with the Big cam..... Convertor, Gearing Ect.
Agree the AFR stuff is a great bang for the $$$ and the bigger ones work great on street stroker motors, the bigger the CID the better.
Your leaving a bunch on the table with the Old Lemans cam, But they do sound cool though. I ran a number of them back in the day......
do i remember reading right that you are now in montreal? I may be driving there in a few weeks after a trip to Ky
i think the cams tight lsa yet long duration mixed with the 185's will help me pull some good midrange power which is really what im after without killing it up top and having something to at least pretend to be torque down low
I just wanted to get as much compression as it can stand to help get every ounce of power i can out of such a small displacement motor.
» Quick and Dirty Rebuild of the 565 - Thanks Lem
» 60' time - how quick is too quick for mech. fuel pump?
» no gutting rules.......B.S.!!!!!
» Gutting a hellcat today !!!
» 460 shortblock all new
