eliminator 605
+31
Tony M
CHARLIEB
darren
yellowhorse7
powerstrokeace
66prostreetfairlane
soupbean
badsnake306
mr.horsepower
Barney
56Tbird
Wheelie58
605FOX
steve1071
35 posters
Page 6 of 10
Page 6 of 10 • 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Re: eliminator 605
thanks my intake looks to take a sbf water neck but its got 3 bolt holes i have a nice bbc i made to work on my ex514 intake but the damn o-ring runs across the "bastard" bolt hole.Barney wrote:I like it. Very nice work.
Re: eliminator 605
cool40 wrote:thanks my intake looks to take a sbf water neck but its got 3 bolt holes i have a nice bbc i made to work on my ex514 intake but the damn o-ring runs across the "bastard" bolt hole.Barney wrote:I like it. Very nice work.
Can't you just have the odd hole welded up and machined down?
Ace
powerstrokeace- Posts : 1496
Re: eliminator 605
i could have done that the sbf neck should cover it tho....powerstrokeace wrote:cool40 wrote:thanks my intake looks to take a sbf water neck but its got 3 bolt holes i have a nice bbc i made to work on my ex514 intake but the damn o-ring runs across the "bastard" bolt hole.Barney wrote:I like it. Very nice work.
Ace
Re: eliminator 605
Lee,
You will most likely need to make some new headers. If not all new headers, then at the least you will need to re-flange the ones you have.
Here's the deal. Your old Ford Motorsports A-460 heads have the exhaust ports on the Ford 4.900" bore spacing and likewise the Chevy header bolt pattern is on 4.900" bore spacing. We used to take a one piece Chevy header flange and saw it completely into in three places (between each port). Then spread everything .060" and bolt them up.
Your current IDT heads have the exhaust ports on the Ford 4.900" bore spacing,,,,,but the Chevy header bolt pattern is on the 4.840" Chevy bore spacing. So, they can take a one piece Chevy header flange,,,,,however the port exit location within the Chevy bolt hole pattern is slightly different on every port.
I would suugest that you make a cardboard or poster board template of the exhaust side of the head. I use a little ball peen hammer and go around tapping in all my bolt holes and also the i.d. of the port itself. Then after proper trimming, lay you template up against your current header flange and you'll see what the differences look like.
Hope this helps,
Uncle Charlie
Hope this helps,
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
Re: eliminator 605
i used chevy headers on the old heads and cut them up like you're talking about.i'll check that out,thanks Charlie!c.evans wrote:Lee,
Hope this helps,
Uncle Charlie
Re: eliminator 605
Vroom vroom....
yellowhorse7- Posts : 1382
Re: eliminator 605
Something tells me this thing is going to be NASTY
soupbean- Posts : 637
Re: eliminator 605
it's sure took long enough i just hope it startssoupbean wrote:Something tells me this thing is going to be NASTY
Re: eliminator 605
i just hate it when things dont work like they should.the damn water pump hose comes out over the nice timing pointer! now i wish i'd a got the remote pump,sob!
Re: eliminator 605
Man that is some awfully nice parts right there!!!
Re: eliminator 605
you need a new water pump?soupbean wrote:Man that is some awfully nice parts right there!!!
Re: eliminator 605
LOL. No but I'll give you 500 for that Dampner and Danny bee
Re: eliminator 605
Ofcourse you might as well throw in that engine plate and timing tab. Hell, might as well throw in the crank trigger deal too
Re: eliminator 605
tight ass......soupbean wrote:Ofcourse you might as well throw in that engine plate and timing tab. Hell, might as well throw in the crank trigger deal too
Re: eliminator 605
Right
Re: eliminator 605
Lee,
The water pump should have two exit holes. Go to the other side (driver) and remove the plug that is that side and then use that same plug and block off the passenger side with it. Then put your hose fitting in the hole on the driver side.
Charlie
Charlie
Re: eliminator 605
c.evans wrote:Lee,
Charlie
He probably has a chevy radiator in it....................
Re: eliminator 605
i have a RJ double pass deal in it.both hoses go on the same side i also have the crank trigger on the driver side,custom hillbilly pickup mounted under the water pump. it aint like i'll be checking the timing much anywayIDT-572 wrote:c.evans wrote:Lee,
Charlie
Re: eliminator 605
not sure why you even need a radiator.......
Re: eliminator 605
105*days,lol.i'm gona start it on gas!richter69 wrote:not sure why you even need a radiator.......
Re: eliminator 605
lastbsummeirbwhen it was 110 plus I used block heaters lol.
Re: eliminator 605
cool40 wrote:it's sure took long enough i just hope it startssoupbean wrote:Something tells me this thing is going to be NASTY
Run it out the other side,it belongs on the D/S SIDE . There should be a plug to remove on the LH. side
BOSS 429- Posts : 2372
» New cylinder heads
» where to buy eliminator heads?
» Eliminator blocks
» New Eliminator intake
» eliminator block
» Eliminator blocks
» eliminator block
Page 6 of 10
