eliminator 605
+31
Tony M
CHARLIEB
darren
yellowhorse7
powerstrokeace
66prostreetfairlane
soupbean
badsnake306
mr.horsepower
Barney
56Tbird
Wheelie58
605FOX
steve1071
35 posters
Page 4 of 10
Page 4 of 10 • 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Re: eliminator 605
i got a few more things from B.F.Evans today! this backup motor is going together fast..
i got these things too,i told Lem i needed some pushrods but these things are kinda big
![eliminator 605 - Page 4 Motor_11](https://i.servimg.com/u/f44/14/44/77/74/motor_11.jpg)
![Twisted Evil](https://2img.net/i/fa/i/smiles/icon_twisted.gif)
![eliminator 605 - Page 4 Motor_10](https://i.servimg.com/u/f44/14/44/77/74/motor_10.jpg)
![confused](https://2img.net/i/fa/i/smiles/confused.png)
Re: eliminator 605
i got some paint on the block too,after i got the goods installed. ![eliminator 605 - Page 4 Motor_12](https://i.servimg.com/u/f44/14/44/77/74/motor_12.jpg)
Re: eliminator 605
Looking Good
res0rli9- BBF CONTRIBUTOR
Re: eliminator 605
Looks great, guess I better bring more jets... Good for you, that thing is gonna be fast as a cat outta water.
Re: eliminator 605
more jetsBarney wrote:Looks great, guess I better bring more jets... Good for you, that thing is gonna be fast as a cat outta water.
Re: eliminator 605
Gotta do something to try to keep up, that things gonna be bad...cool40 wrote:more jetsBarney wrote:Looks great, guess I better bring more jets... Good for you, that thing is gonna be fast as a cat outta water.i'll have the little one in the car so it'll be easy for you,lol.
Re: eliminator 605
that short clip of yours running dont sound bad.Barney wrote:Gotta do something to try to keep up, that things gonna be bad...cool40 wrote:more jetsBarney wrote:Looks great, guess I better bring more jets... Good for you, that thing is gonna be fast as a cat outta water.i'll have the little one in the car so it'll be easy for you,lol.
![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png)
Re: eliminator 605
i just love finding shit i forgot i already had,lol.the kaase pump was hid in the crankshaft box! i hate to grind on it but the crank hits it
![eliminator 605 - Page 4 Motor_13](https://i.servimg.com/u/f44/14/44/77/74/motor_13.jpg)
i also dusted off the "pro baller"oil pan cuz i could'nt wait to see it on BUT i forgot about the holes i should'a drilled at the rear of the block for pan bolts!
![eliminator 605 - Page 4 Motor_14](https://i.servimg.com/u/f44/14/44/77/74/motor_14.jpg)
![Suspect](https://2img.net/i/fa/i/smiles/suspect.gif)
![Mad](https://2img.net/i/fa/i/smiles/icon_mad.gif)
Re: eliminator 605
i cant say enough about the ww rockers!
i had to work in the head gasket a little for the big ass pushrod
![eliminator 605 - Page 4 605_lo10](https://i.servimg.com/u/f44/14/44/77/74/605_lo10.jpg)
![pale](https://2img.net/i/fa/i/smiles/icon_pale.gif)
![eliminator 605 - Page 4 605_lo11](https://i.servimg.com/u/f44/14/44/77/74/605_lo11.jpg)
Re: eliminator 605
Looks Good with them Procomp/P51 Heads ,Did K/Jelly get them for ya
![Razz](https://2img.net/i/fa/i/smiles/icon_razz.gif)
Re: eliminator 605
them procomp-51's aint got shit on these........res0rli9 wrote:Looks Good with them Procomp/P51 Heads ,Did K/Jelly get them for ya![]()
Re: eliminator 605
Awsome engine build. That thing is a beast. What's your hp predictions
badsnake306- Posts : 131
Re: eliminator 605
i have no idea but i hope its more than i have now.lolbadsnake306 wrote:Awsome engine build. That thing is a beast. What's your hp predictions
Re: eliminator 605
cool40 wrote:i cant say enough about the ww rockers!![]()
Lee,
Thanks for the complimentry words about the W.W. Engineering rockers. I'll pass it on to Wild. Guys, that's the latest version of A-460 rockers that you're looking at with the one piece intake stand that runs the full length of the head.
My concern is your head gasket. That looks like a 10 bolt gasket to me and I'm thinking it's a Cometic. Please check and see if the rivets of the 10 bolt gasket are laying on the block and partially caught under the heads. If they are remedy as neccessary. IMO when using an 18 bolt block such as yours, you should go ahead and order the 18 bolt head gasket, even if you are using a 10 bolt head such as your Eliminators. The rivets on the 18 bolt gasket are in a different place as compared to the 10 bolt.
Charlie
c.evans- BBF VENDOR SPONSOR
Re: eliminator 605
the rivets are out from under the head.they do lay on the block but not the head.the spring is sure close to the valve cover and the intake rockers are too
![eliminator 605 - Page 4 605_lo13](https://i.servimg.com/u/f44/14/44/77/74/605_lo13.jpg)
![Shocked](https://2img.net/i/fa/i/smiles/icon_eek.gif)
![eliminator 605 - Page 4 605_lo12](https://i.servimg.com/u/f44/14/44/77/74/605_lo12.jpg)
Re: eliminator 605
Lee,
Because those are 1750 body rockers, (instead of the more common 1650 body rockers) then they are up towards the intake manifold more. I have had to put some serious notches in the cast valve covers and also do a little grinding or should I say "profiling" of the rocker body itself. If you are running billet rail valve covers, you will probably have to grind four notches in the rails.
An advantage of the 1750 body verses the 1650 body is that the roller has less sweep across the tip of the valve.
Hope this helps,
Charlie
Hope this helps,
Charlie
Re: eliminator 605
the intake are 1775,ex are 1750.i ordered some moroso $gold$ today,i'm still a little sick over the price.c.evans wrote:Lee,
Hope this helps,
Charlie
Re: eliminator 605
damn,this is gona take a while
![eliminator 605 - Page 4 605_lo14](https://i.servimg.com/u/f44/14/44/77/74/605_lo14.jpg)
Re: eliminator 605
I just put the iPod on and get to grinding, it will be over before you know it. Looking good btw.cool40 wrote:damn,this is gona take a while![]()
Re: eliminator 605
it aint so bad,it's almost done now.
Re: eliminator 605
Referring to that current 5 second beast as "the small motor"
soupbean- Posts : 637
Re: eliminator 605
it is small for todays standards.this 605 aint "big"anymoresoupbean wrote:Referring to that current 5 second beast as "the small motor"![]()
![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
Re: eliminator 605
If I was packing a 605, I'd be John Holmes around here!
![affraid](https://2img.net/i/fa/i/smiles/affraid.gif)
Re: eliminator 605
finished the intake today. ![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png)
![eliminator 605 - Page 4 Intake14](https://i.servimg.com/u/f44/14/44/77/74/intake14.jpg)
![eliminator 605 - Page 4 Intake12](https://i.servimg.com/u/f44/14/44/77/74/intake12.jpg)
» THANKS Eliminator Products
» WTB Eliminator block
» eliminator sportsman block?
» Eliminator Block
» New cylinder heads
» Eliminator Block
Page 4 of 10
