Duraspark Ignition
Duraspark Ignition
I have a wiring harness, Duraspark ignition and 460 out of a 1976 Thunderbird that i'm putting into a 1965 Galaxie 500. I was curious if anyone had a basic wiring diagram for the ignition system? I have a Duraspark II diagram that looks similar but it shows a ballast resistor. The Thunderbird did not use one to my knowledge. on the thunderbird starter relay it only used the 1 wire red/blue starter wire.. the ignition post was unused. on the Galaxie both terminals are used.. so if anyone could shed any light on the wiring
Ignition box:
wires Green , orange, purple and black are pretty simple since they were still connected to the distrib and coil.
Red: -> ( run ) ignition switch and then to the ignition terminal on the starter relay?
White: -> ( start ) ignition switch T'd into the red/blue wire that goes to the starter relay terminal.
Thanks for any help.. again it is not a Duraspark II. its just a Duraspark. No ballast resistor.
Ignition box:
James1965- Posts : 21
Re: Duraspark Ignition
Its a sticky at the top of this/ engine tech page
https://www.429-460.com/t4757-ford-factory-ignition-modules
res0rli9- BBF CONTRIBUTOR
does it matter that they show it as a duraspark II diagram? is there a ballast resistor for this that I need? I did not see one on the Thunderbird when i removed most of the engine harness. and the Thunderbird starter Relay only used the starter post on the relay the ignition side was unused. I'm not doubting anyone's info, i'm just trying to clarify is all. I thank you all for the help.
James, on my 65 fairlane with the duraspark 2, I did not use a ballast resistor. now don't leave the key on for extended periods of time( like 3 hours for me)...I burnt up the ignition coil.....but my D 2 works great!
'65 T-BOLT- Posts : 1464
» msd distributor on duraspark ignition?
» Duraspark ignition question
» Duraspark ?
» Cheap Ignition
» Will a 351W distributor work in a BBF?
» Duraspark ?
» Cheap Ignition
