How to convert a 3 circuit to 2?
How to convert a 3 circuit to 2? Empty How to convert a 3 circuit to 2?
Post  powerstrokeace September 14th 2011, 1:25 am
Just like the title say's. How can you convert a 3 circuit 1050 to a 2 circuit carb? this E85 shit it really messing me up right now. So I want to put a gas carb back on for the last 2 race's
Ace
powerstrokeace
powerstrokeace
How to convert a 3 circuit to 2? Empty Re: How to convert a 3 circuit to 2?
Post  TommyK September 14th 2011, 5:34 am
http://motorsportsvillage.com/forum/viewtopic.php?t=3742
TommyK
Post  BOSS 429 September 16th 2011, 10:19 pm
why in the world would you change a fully tunable carb to one thats not?
Post  powerstrokeace September 17th 2011, 12:32 am
this carb is not tunable. It can only have jet changes and power valve and squirter changes. It been rumored that the 2 circuit carbs are better for super class racing and I was looking to go back to a gas combination after using E85. It's like hell to predict what going to happen in cooler weather. But after talking with Gary Stinnett he thinks the 3 circuit is the way to go and who's to argue with a class champion like Gary. Now for a sum he will maximize the tune up and put changeable air bleeds in it and make it even better than what it is.
Ace
powerstrokeace
powerstrokeace
Post  jc10000rpm September 17th 2011, 9:09 am
iv had good luck with my e-85 three circuit, as far as weather and temp, i run a 165 degree thermostat with a 5/32 bleed hole drilled in it. two nights ago it was in the low 50's, i hardley ever had to turn the fan. so far i really like running the thermostat set-up, makes easy work of it at the track. iv thought about switching out to a higher temp t-stat to campare the results
jc10000rpm
Post  BOSS 429 September 18th 2011, 12:51 am
powerstrokeace wrote:this carb is not tunable. It can only have jet changes and power valve and squirter changes. It been rumored that the 2 circuit carbs are better for super class racing and I was looking to go back to a gas combination after using E85. It's like hell to predict what going to happen in cooler weather. But after talking with Gary Stinnett he thinks the 3 circuit is the way to go and who's to argue with a class champion like Gary. Now for a sum he will maximize the tune up and put changeable air bleeds in it and make it even better than what it is.
Ace
ya thats what i meant from 3 to a 2 is going backwards
