convert a propane 460 to gasoline
Just wondering if anyone here has tackled such a job or not. I see a cheap 460 in the local classifieds that has run solely on propane. From what i understand, propane is very gentle on the internals, and wear life is extended. This is already a low mileage motor. So, whats involved? Just a new intake and carb and fire it up? It's a '85 model.
I did a quick search of the site and didnt see any other topics on this so if its a repeat, i apologize.
olschoolsteel- Posts : 34
Re: convert a propane 460 to gasoline
Would it be as simple as replacing the fuel delivery system? Technology may have progressed in this area, the earlier conversions (gas to propane) produced trouble for the exhaust valves and seats. That may not be the case now days. So IMO, change fuel delivery and experiment with ignition timing.
Dave.
Dave.
LivermoreDave- Posts : 972
I'm hopin it would be that easy. I cant imagine that the internals would be much different than a stock gasoline 385 series.
There were two versions of the Natural gas/propane engine, a high compression version and a low compression version. Even though the propane engine may be low mileage, the dry nature of the fuel is hard on exhaust valves. If it runs good, and has decent compression, I'd say go for it if the price is acceptable to you. Some of these engines were shipped from the factory with the old DOOE (Cobra Jet) intakes on them. Either way these engines have standard 4bbl intakes on them, and all you have to do is remove the gas mixer and install a carb of your choice. There is a fuel pump block off plate on the timing cover that will accept a standard fuel pump. The distributor may be a marine style, and I would ditch it in favor of a standard Dura Spark dizzy.
schmitty- Posts : 4538
Now thats some good info. From the pics i couldnt tell if it was a propne specific intake or not, but i had a spare cast iron intake just in case. I will go look it over to see if its a good one to drop in and fire up. I think i still have an old single point dist i can use as a trade in (at autozone) for a durasprk set up if is indeed a marine style unit.
What kind of intake does it have now? I thought the 85 already used a carb from the factory. Anyways, just change out the propane carb (called a mixer) with a regular Holley etc. Check your timing and recurve the distributor if needed.
jasonf- BBF CONTRIBUTOR
» What gasoline to use????
» Propane 460 backfiring
» How to convert a 3 circuit to 2?
» HOW TO CONVERT FROM 110 OCTANE TO E85??
» convert 92 F350 to 4wd
