reverse rotation on a BBF
hpwdboss1
DanH
Frank Kramer
reverse rotation on a BBF Empty reverse rotation on a BBF
Post  Frank Kramer October 1st 2011, 5:37 pm
Planning to reverse the crankshaft rotation on 2 of our engines.
Has anybody done this before on a BBF???
Any idea's / suggestions were to look at are welcome.
Thanks Frank
Frank Kramer
Frank Kramer
http://www.seasideaffair.com
reverse rotation on a BBF Empty Re: reverse rotation on a BBF
Post  rmcomprandy October 1st 2011, 8:08 pm
Frank Kramer wrote:Planning to reverse the crankshaft rotation on 2 of our engines.
Thanks Frank
Twin engine marine cruisers use counter rotating engines. Whatever they use should give you a good idea of how to get there.
Camshaft, 2 gear drive timing set and starter are for sure ... some Chevy guys get their crankshaft made with the passages in the crankshaft reversed for oiling in high RPM stuff.
Post  DanH October 2nd 2011, 10:32 am
good point on the crank oiling (rod pin oil hole clocking)
DanH
Post  Frank Kramer October 3rd 2011, 4:04 am
Thanks Frank
Thanks Randy,
Was planning to modify 2 of my current engines for this. But you are already the 2nd one that made a comment about reversed oiling in the crankshafts. Looks like I have to order 2 new billets also soon. That starter isn't a big problem for us. We have a hydraulic starter mounted on the gearbox...
Frank Kramer
Frank Kramer
Post  rmcomprandy October 3rd 2011, 9:18 am
Thanks Frank
Thanks Randy,
Regular oiling indexing will work at a mid level RPM range ... (around 6,800 RPM or so).
Post  Frank Kramer October 4th 2011, 3:52 am
running 7500 plus.. so that will probaly not work for us.
Frank Kramer
Frank Kramer
Post  hpwdboss1 October 6th 2011, 9:17 am
Frank,
I have worked around several emergency electric generators that run BBF's backasswards. There are certainly starters and other ancillary equipment available, and as was stated earlier, twin engine watercraft do this alot. Good luck!
Perry
hpwdboss1
hpwdboss1
Post  dfree383 October 6th 2011, 9:25 am
Stupid Question Can you Just turn the motor around and Power off the Crank Snout?
Post  schmitty October 6th 2011, 12:06 pm
dfree383 wrote:Stupid Question Can you Just turn the motor around and Power off the Crank Snout?
Not sure if this helps or not, but back in the old days if you had a large or extremely deep irrigation well, we would tie two together, and drive one off of the other with a driveshaft from crank snout to output shaft. There are still several out there running this way still. Cool
Post  jesse October 6th 2011, 12:52 pm
i might be wrong here but as far as i know
even thou it is has multiple engines each one
still has it own bell housing and clutch
back in the old days ppl would tie them together but
you can never get 2 motors to run exacly them same
close but not 100% think of it like like running a race and having 1 leg
tied to your prarnters you will go but not as fast as if you were running buy
yourself
jesse
jesse
Post  meandad October 9th 2011, 8:46 am
dont forget the crank seals are differnt also
meandad
http://jpsherte@hughes.net
Post  Frank Kramer October 9th 2011, 8:59 am
Crank to crank is to muck trouble.... Clutches... Blower belts ... Crankshaft...
Prefer to run each engine with its own clutch.
Frank Kramer
Frank Kramer
Post  Frank Kramer October 9th 2011, 9:01 am
meandad wrote:dont forget the crank seals are differnt also
You are not the first one telling that. Only still need to know a place where I can get the good ones.
Frank Kramer
Frank Kramer
Post  DanH October 9th 2011, 10:31 am
why would the seal be different ?
same seal on the FE' 427 , crank hatch marks were opposite
DanH
Post  DanH October 9th 2011, 10:38 am
Frank Kramer wrote:running 7500 plus.. so that will probaly not work for us.
Capping/plug the lighten throw hole (like the FE427/Boss429 and crossdrill the pin like the Boss9 crank .
That saves a lot of money if it would work .. don't see why it shouldnt
DanH
Post  meandad October 11th 2011, 10:12 pm
I would think a mercruiser dealer would be a good place to look. aint the reverse rotating engine old school now?I thought they just use standard rotation and do it with the gear in a marine app.I've seen the reverse FE and reverse mopars but not a reverse 460.not saying they didnt have them,just never seen one.
meandad
Post  meandad October 11th 2011, 10:24 pm
some of the seals have the "hatch marks" on them also.They would probably leak like hell if they were facing the wrong way.
meandad
Post  dfree383 October 12th 2011, 2:32 am
I have a pair of FE 427's in my boat. But honestly they are not intended for high RPM operation. 3500 ish is about it.
