Converter rotation
Converter rotation Empty Converter rotation
Post  HorsinAround January 5th 2022, 9:17 pm
Quick question. When you get a converter fully seated into the pump, will it rotate? Or, do you have to slide it forward a little to get it to spin?
Got this trans back from the shop and it's sat for a year now without a converter in it. I put a new 300m shaft in tonight and put the converter in it for storage and noticed the converter doesn't turn when it's fully to the rear. When I did the video's below to show you guys, I re inserted the pump, and pushed a little and the converter started rotating. Is something wrong with the pump or is this ok now?
https://youtu.be/giLpCA75QCY
https://youtu.be/37NUoRzAfxY
http://www.frontpagefab.com
Converter rotation Empty Re: Converter rotation
Post  BBFTorino January 5th 2022, 11:00 pm
It should spin no matter what. If it don't spin, then something is binding and preventing it from rotating.
Post  Gregaust January 6th 2022, 4:11 am
As above yes , even right in it should still turn. You may feel a slight drag as the pump gears turn but it should still be free not tight
Gregaust
Post  HorsinAround January 6th 2022, 10:14 am
That is what I thought, but didn't have another trans handy to compare to. I'll pull the pump this weekend and see whats going on with it.
Post  Gregaust January 7th 2022, 3:19 am
HorsinAround wrote:That is what I thought, but didn't have another trans handy to compare to. I'll pull the pump this weekend and see whats going on with it.
I think that'd be a wise move , something not right there ..
Gregaust
