p51 vs. tfs a460 340-m-83
+11
1970 ford maverick
15 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: p51 vs. tfs a460 340-m-83
Lem Evans wrote:"""I guess I'm a retard....my 1st A460 deal was 4.375" bore [+.015"] x 4.140"...SCJ block...2.350"/1.900" ...498".
Then I sold all my stuff so I could go to 4.50" x3.920"....and lost power.
Amen, been there too.
Gary Blair- Posts : 221
Thanks JB,I believe theres alittle more on the table,we are putting the 4.30s in this weekend,taking some fuel out ,Hopeing for some 50s,Any suggestion?,Thinking were going to build around the A-460s for a stronger motor later on down the road.Thanks1970 MAV.jbozzelle wrote:1970 ford maverick wrote:........................ We know we need a better head to go faster................
Not exactly. I think you have a lot left in that existing combo...
1970 ford maverick- Posts : 180
Us too,don,t want to go back down that slow road again!Thats why were here,A little FAST FORD LOVE goes alog way,Thanks 1970 MAV.Gary Blair wrote:Lem Evans wrote:"""I guess I'm a retard....my 1st A460 deal was 4.375" bore [+.015"] x 4.140"...SCJ block...2.350"/1.900" ...498".
IMHO that is not too bad, but by the time you add proper hardware, and depending on how good the valves are, you might be better off buying new heads complete, and finding a used intake. You can get quite a bit of $$ in the springs and hardware depending on what you decide to buy. Are these heads ported in any way? How used up are the valves?
schmitty- Posts : 4538
Thanks Schmitty,The a-460,s are brand new with valves only, untouched with new matching intake and new header flanges. New int.and exh.$2,OOO?schmitty wrote:IMHO that is not too bad, but by the time you add proper hardware, and depending on how good the valves are, you might be better off buying new heads complete, and finding a used intake. You can get quite a bit of $$ in the springs and hardware depending on what you decide to buy. Are these heads ported in any way? How used up are the valves?
The price for those heads and intake is great. Summit has them for $1950 EACH fully dressed with springs, etc...
Dig around the PROVEN BUILDS section here. It's got a bunch of 514/521 combos that you can look and chew at. Jon (richter69) ran 9.20s with a 524 and the TFS Street heads in a 69 Stang. I now have his old cam in my 514/P51 combo. The specs on it are 276/287 @ .050 and .763/.761 lift. That cam you have is small for the cubes on that 521. Remember big cubes makes duration on a camshaft seem small... You need a bunch more duration and lift to effectively fill the cylinders.
How good does it rev past 5000 on motor alone? Does it pull really good or does it need the spray to make it pull up top?
jbozzelle- Posts : 3705
I went 9.01 with the 529 and the street heads, it went some 5.60's in the 1/8th on M5 and in good air............
and yes you have that cam I did it with.
richter69 wrote: and yes you have that cam I did it with.
And hopefully in a few months I'll tell you how fast it runs with 15 less cubes, equal or better heads and in a Fox body on GAS...
richter69 wrote:and yes you have that cam I did it with.
you did it with a cam ?
disgusting pervert
John Myrick- BBF CONTRIBUTOR
Lem Evans wrote:A big "me too" for more cam duration....
Does that mean you want to have your way with a cam for a longer time????????????????
Curt- Posts : 2791
Curt wrote:Lem Evans wrote:A big "me too" for more cam duration....
Only if it's one of those wife swaping cams like you run
Only if it "lifts" up his you know what...
Thanks for the specs,we run mostly 1/8 mile and she pulls hard all the way.6.13@111, i think it,s a real torque monster to be so mild. I only turn it 6000-6500max.Thanks1970 MAVjbozzelle wrote:The price for those heads and intake is great. Summit has them for $1950 EACH fully dressed with springs, etc...
1970 ford maverick wrote:Cam is a Reed, Old solid lift,Here are the #266/272 - 647/653 - 110 - 2degrees retard,Thanks Again,1970Ford Maverick.
Your car runs very good. Like everyone has said you have some room to grow with what you have for sure. With 12.8-1 you could run more cam. I like to push it a bit on camshaft. I would like 280°-282° on the intake and 288°-292° exhaust on a 112° LC in @ 106. I like Mavericks, you don't see many nowadays.
Thanks GB, Were proud of her,and will keep on tweaking.Thanks 1970 MAV.Gary Blair wrote:1970 ford maverick wrote:Cam is a Reed, Old solid lift,Here are the #266/272 - 647/653 - 110 - 2degrees retard,Thanks Again,1970Ford Maverick.
Here,s a photo of the Mav @Douglas,Ga. Little outlaw track in South Ga.5.73@118 -1/8 Hope you like it!,Thanks1970MAV1970 ford maverick wrote:Thanks GB, Were proud of her,and will keep on tweaking.Thanks 1970 MAV.Gary Blair wrote:1970 ford maverick wrote:Cam is a Reed, Old solid lift,Here are the #266/272 - 647/653 - 110 - 2degrees retard,Thanks Again,1970Ford Maverick.
1970 Mav where are you located I see you said you have run in Douglas I am about 45 mins away from the track in Douglas Ga
Jim
Jim
Northside of Jacksonville,Fl.69F100 wrote:1970 Mav where are you located I see you said you have run in Douglas I am about 45 mins away from the track in Douglas Ga
Jim
Here is something for the Maverick fans......
THANKS MR.EVANS for the PHOTOS,LOVE THEM MAVERICKS! THANKS 1970 MAVLem Evans wrote:
70 did they get the dip in the track fixed last time we was at douglas with my buddy's car the track was junk he like to lost it twice with the dip at half track it was up setting the car.Then they was a mustang hit the gaurd rail just pass the finish line.I have run Douglas with my truck I always go to Cecil or Albany,Albany is not better but they prep their track alittle better.
1970 ford maverick wrote:Yes sir,we have been running all motor with the 4.88s,got 4.33s that is going in soon,So that we can get alittle more agressive with the nos tune,and we have a nice Solid Roller for the new heads when we decide which head were going with.,Still, we are ole school,and will keep on tweaking on the MAV.Thanks 1970 maverick.jbozzelle wrote:Bang for the buck speaking...
I'd get the heads looked at by a pro and new roller cam matched to what you have along with possibly a gear and converter tweak... It'll be cheaper than a full change including heads. That old cam is hurting the combo IMO.
My ? IS. How can you already have the RIGHT cam,when you haven't decided what heads you are going to go with?
What are the specs on the solid roller you have? Why not stick it in now and see what it'll do?
» Ford Motor Sport A460 Intake Part # M-9424-a460 125.00 shipped
» meziere pump ,A460 head studs,new style A460 intake
» Cometic MLS head gaskets
» question on compression ...using pump gas (a460...using fms a460 heads)
» Question about TFS A460 and Motorsport A460 heads
Page 3 of 4
