p51 vs. tfs a460 340-m-83
+11
1970 ford maverick
15 posters
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Re: p51 vs. tfs a460 340-m-83
1970 ford maverick wrote:Northside of Jacksonville,Fl.69F100 wrote:1970 Mav where are you located I see you said you have run in Douglas I am about 45 mins away from the track in Douglas Ga
Jim
Must suck with Jax Raceways closed, huh
jbozzelle- Posts : 3705
BIG TIME BRO ! And yeah,theres a bump down track at Douglas , not as bad ,but still there.jbozzelle wrote:1970 ford maverick wrote:Northside of Jacksonville,Fl.69F100 wrote:1970 Mav where are you located I see you said you have run in Douglas I am about 45 mins away from the track in Douglas Ga
Jim
1970 ford maverick- Posts : 180
Well ,I didn,t say it was the "RIGHT"cam I just said we have one.It,s in my 514 with C8,s that,s been worked over,Exh. has been raised 5/8ths ,Int. has been matched to scj and both opoxyed,it,s a 14.7.1 comp.engine,Will look for card tomorrow and we will see what you think?Racing on a small Budget!bbf-falcon wrote:1970 ford maverick wrote:Yes sir,we have been running all motor with the 4.88s,got 4.33s that is going in soon,So that we can get alittle more agressive with the nos tune,and we have a nice Solid Roller for the new heads when we decide which head were going with.,Still, we are ole school,and will keep on tweaking on the MAV.Thanks 1970 maverick.jbozzelle wrote:Bang for the buck speaking...
I'd get the heads looked at by a pro and new roller cam matched to what you have along with possibly a gear and converter tweak... It'll be cheaper than a full change including heads. That old cam is hurting the combo IMO.
My ? IS. How can you already have the RIGHT cam,when you haven't decided what heads you are going to go with?
Just got out of the garage ,this cam is out of my 514 iron headed baby.Im not sure of the exact #s, for its been about 8 years sense we ran it ,280ish and 750ish,like i said,it,s been awhile.Here are the #s off the back of cam R-2861-456-251-10,I tried to find card tonight but no luck!Hopefully better luck tomorrow,I tried to look it up on cranes net earlier ,no luck,will call tomorrow.I did,nt have enough clearence on this set up,had bottom end together ,mocked up top end and only had about 65ths ,so we went with what we knew would work.The valve reliefs were small I thought,the pistons are JE,S.THANKS 1970 MAVjbozzelle wrote:What are the specs on the solid roller you have? Why not stick it in now and see what it'll do?
Just found my card,here we go,With 1.7,s 780I AND 727E,286I and 294E, 110LS ,105 INTAKE with a RPM range of 5000-8500 LASH, HOT 26.-26. Thanks 1970 MAV1970 ford maverick wrote:Just got out of the garage ,this cam is out of my 514 iron headed baby.Im not sure of the exact #s, for its been about 8 years sense we ran it ,280ish and 750ish,like i said,it,s been awhile.Here are the #s off the back of cam R-2861-456-251-10,I tried to find card tonight but no luck!Hopefully better luck tomorrow,I tried to look it up on cranes net earlier ,no luck,will call tomorrow.I did,nt have enough clearence on this set up,had bottom end together ,mocked up top end and only had about 65ths ,so we went with what we knew would work.The valve reliefs were small I thought,the pistons are JE,S.THANKS 1970 MAVjbozzelle wrote:What are the specs on the solid roller you have? Why not stick it in now and see what it'll do?
Will that cam fit in the 521? If so, I'd try it...
No luck, I tried,but not enough room and we had the short blk together already.Thanks,1970MAVjbozzelle wrote:Will that cam fit in the 521? If so, I'd try it...
» Ford Motor Sport A460 Intake Part # M-9424-a460 125.00 shipped
» meziere pump ,A460 head studs,new style A460 intake
» Cometic MLS head gaskets
» question on compression ...using pump gas (a460...using fms a460 heads)
» Question about TFS A460 and Motorsport A460 heads
Page 4 of 4
