429 block ?
jason
Page 1 of 2
Page 1 of 2 • 1, 2
429 block ?
I've got a 1968 429 block , and I was wondering if they are as strong as the later blocks ? I'm looking at doing a 502 or 521 stroker from coast high performance to put in my 68 dodge dart, it would be numbers matching then being from the same year
jason- Posts : 220
Re: 429 block ?
Now thats a great project.... Putting a Ford engine in a mopar !!!
Yes all the 2 bolt blocks are equal, the later ones just have longer cylinders.
Re: 429 block ?
I can just see the look on the mopar guys faces when you tell them you have a numbers matching car and pop the hood !!! Priceless !!!
Re: 429 block ?
I did a backhalf for this die hard dodge guy and he gave me the dart , it's just a shell but it's in good shape . I can't wait to see the look on his face . I'm sure I'll get some good responses at the track to .
jason- Posts : 220
Re: 429 block ?
The only thing cooler would be to put hemi heads on it
56Tbird- BBF CONTRIBUTOR
Re: 429 block ?
I thought about using boss heads but I need a set of a-460's for my mustang so I'll put the edelbrocks on the dart engine.
jason- Posts : 220
Re: 429 block ?
I'd just tell them is a stroked wedge with a date matching block. Then wait for it when they see it !!!
Re: 429 block ?
I'll use that ,and the cherry on top will be when I tell them I wanted to go fast .
jason- Posts : 220
Re: 429 block ?
So if the early blocks have short cylinders , how many cubes can they be stroked to ?
jason- Posts : 220
Re: 429 block ?
a 4.5" with a 6.7 or 6.8 rod is very common and fits fine. and with a .080 over bore that gives you a 557, but its a good idea to sonic the block before boring it.
Re: 429 block ?
I'm not gonna go past a 521 , I'm not gonna get crazy with this one it's gonna be pump gas .
jason- Posts : 220
Re: 429 block ?
jason wrote:I'm not gonna go past a 521 , I'm not gonna get crazy with this one it's gonna be pump gas .
a 545 with a 4.5 arm and a .030, inches are your friend, for power and it doesn't cost any more to get a 545 than a 521
Re: 429 block ?
I'll look into the 545 , I thought I heard something about pump gas not working as good in higher cubed engines , don't know if it's true , but a .030 over sounds good , I don't wanna take to much cylinder away
jason- Posts : 220
Re: 429 block ?
big cubes or small , the build will say what fuel is needeedjason wrote:I'll look into the 545 , I thought I heard something about pump gas not working as good in higher cubed engines , don't know if it's true , but a .030 over sounds good , I don't wanna take to much cylinder away
DanH- Posts : 1081
Re: 429 block ?
I like the idea but knowing some Mopar guys I think you would be better to keep the hood shut as much as possible they are the ones that would slit your throat for something like that.
Re: 429 block ?
I'm sure , but half my friends are dodge guys and they know it's a budget deal , and it's cheaper to put a ford in it than buying everything new , I have the block intake and heads . It'll be fun when the anouncer at the track says what's in it before the burnout .
jason- Posts : 220
Re: 429 block ?
Lol true, I laugh as the announcer at my home track always mentions that my truck no longer has the original 4 banger in it even though I run no hood and everyone can clearly see that.
Re: 429 block ?
I don't know what trans to Put in it, P/A or dynamics c-4 or an overdrive with a brake of course . I've already got a 9" I just have to put ladder bars on it . Another one of the mopar guys I know said if I put a ford in it he wouldn't talk to me anymore , So that's what it takes, if I only knew that sooner.
jason- Posts : 220
Re: 429 block ?
C6 or a glide.
Re: 429 block ?
I've got a glide in the mustang and I'm not impressed. Who does a c-6 that can take a beating ? I'm lookin at making around 600-650 N/A and spray 250 .
jason- Posts : 220
Re: 429 block ?
Frank Merkel is your man.
Re: 429 block ?
How do I get a hold of him ?
jason- Posts : 220
Re: 429 block ?
jason wrote:How do I get a hold of him ?
Here give him a PM
https://www.429-460.com/t11533-update-from-mission-by-frank-merkl
res0rli9- BBF CONTRIBUTOR
Re: 429 block ?
Ok thanks I just pm'd him , I just raised the trams tunnel 2-1/2 " cause there's no room when you put a scatter shield on them , it should be interesting .
jason- Posts : 220
Re: 429 block ?
Here's a thread that he give's a lot of info. in, long but very good info..
http://www.460ford.com/forum/showthread.php?t=113120
Page 1 of 2 • 1, 2
» distributer block hole is too small on an A460 block
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» Will a manual block plate from a 77 bronco fit a 71 429 thunderjet block?
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» 540 Long block / Boss9 block / AR CJ cylinder heads - $3300 OBO
Page 1 of 2
