Firing order swap
Firing order swap
What would be the advantage or reason to swap the firing order on #8 and #2 cylinders?
I was looking at some roller cams on Cranes' website and they have these listed as SF01 firing order.
I used the forum search but found nothing about this.
Thanks.
Thanks.
STR-LGL-70- Posts : 223
Re: Firing order swap
From my understanding it reduces the pressure on the crank throws and gives you a little bit more power.
Dan
Dan
» Firing order swap
» Firing Order Swap Cores
» NEED FIRING ORDER ASAP
» Question regarding firing order of 429-460
» Firing new motor
» Firing new motor
