Firing Order Swap Cores
kjett
pmrphil
wickettoby1
I did some searching on the “google machine” but all of the info that I found was several years old. So my question is what is the availability of firing order swap cores for flat tappet and roller cams? Also what’s the availability of billet cam cores with with a cast iron distributor drive gear?
Justin
Justin
wickettoby1- Posts : 352
Re: Firing Order Swap Cores
I may be wrong, but when it comes to anything that's not Chevy, I doubt that you'll find anything off the shelf or 'in stock'.
It would have to be custom ground.
BBFTorino- Posts : 999
That's why I was asking about cam cores not pre ground cams sitting on someone's shelf.
The 'swap' cams I have ground come from Comp. Different cores are required depending on dur, lift and LSA.
I don't believe billet cams for a Ford are available with a cast gear, only GM stuff. They can pin the gear at the rear, but I don't think they can make it strong enough to drive the entire camshaft.
pmrphil- Posts : 171
Lem
Did you do the firing order “swap” at the customers request or did you see a value in it yourself? I could see the benefit to the cooling system in not having 7 and 8 fire in order. It also seems like swapping 4 & 8 would even out the torsional forces on the crankshaft.
Justin
Justin
Phil
That’s what I was wondering but you never know what “skunk works” types of things guys are working on or hiding
Justin
Justin
wickettoby1 wrote:Lem
Justin
I'm not Lem, nor am I anywhere near an expert, but when I called Bullet not too long ago to order my new cam for my 600+" mud race motor I specifically asked about getting a swap cam for it. They told me that in the fords they didn't see that much of a benefit over the cost/hassle to do the swap and they have been seeing just as much power by using a "stock" firing order grind. He said it will come down to whatever I want, but recommended I stick with the traditional firing order in my bbf.
kjett- Posts : 1169
Yep ... you can get whatever you want in a billet however, you are going to pay for it ... considerably.
I'm not an expert, but I do remember Jon Kaase saying at one of the Winter Tech Seminars that it was his observation that the swap was easier on the bearings and crank.
If a stock firing order billet is $XXX does the firing order swap add $50, $100, $200 to the price? Everyone knows that a custom ground cam is going to be more expensive then off the shelf but in my opinion a couple hundred dollars on a $6-8K engine build is a small price to pay for an optimized combination.
Justin
Justin
wickettoby1 wrote:Randy
Justin
If your running a flat tappet your wasting your time with the alt firing order stuff.
And in all honesty a $6-8k build probably isn’t going to benefit from the expense either.
The money is better spent elsewhere on things like lighter rotating assemblies, higher quality lifters and better valvrain components, porting, better oiling systems ect.
I order mine through LSM engineering. Same cost or maybe very little upcharge for a 2 -8 swap. They make most of the cores for just about every custom cam. They also have some very good springs.
LSM Systems Engineering
Curt- Posts : 2791
Doug Rahn wrote:I'm not an expert, but I do remember Jon Kaase saying at one of the Winter Tech Seminars that it was his observation that the swap was easier on the bearings and crank.
Correct.
Not all cores are the same price by a long shot. The one I use the most is under $500 with 8/2 swap with dual pin holes included. Others are $700+.
kjett wrote:wickettoby1 wrote:Lem
Justin
Wow, seems the guys thinks it a benefit for a Chevy but, not a Ford.
Lem Evans wrote:kjett wrote:wickettoby1 wrote:Lem
Justin
Lem, you just reminded me of something from the old Networkk54 forum that you posted.
If you look at the Chevy and Ford firing order , as a circle (as it is on the dist. cap) it's the same. The Chev. deal starts at our #5 and runs the same course. The swap they do eliminates #5 and #7 from firing back to back. This is the same as our #7 and #8 going back to back. The 351W is a diff. deal @ 1-3-7-2-6-5-4-8.
Justin
Understanding the difference between the price of grinding a "UGL" and a "round core billet" with the extra operations it takes to get a finished camshaft tells the entire story.
A "UGL" billet has the lobes already clocked and hardened and then is merely finish ground to the specific lobe profiles.
Those different firing orders which are not available in a UGL require a "round core billet" because the clocking of the lobes is completely different.
A "round core billet" is about a little over twice the manufacturing cost to get to that hardened finished product.
Thanks Lem
» Firing order swap
» Firing order swap
» Question regarding firing order of 429-460
» NEED FIRING ORDER ASAP
» Need help engine quit firing
» Firing order swap
