NEED FIRING ORDER ASAP
J R
FOR THE BBF 460 THANKS.
J R- Posts : 82
Re: NEED FIRING ORDER ASAP
J R wrote:FOR THE BBF 460 THANKS.
1-5-4-2-6-3-7-8
Nevs- BBF CONTRIBUTOR
It's still backfiring
J R- Posts : 82
do you have it 180% off ?
Northwest outlaw- Posts : 962
Yes,it cranks but it cuts right offNorthwest outlaw wrote:do you have it 180% off ?
J R- Posts : 82
Jason was asking if your distributor is out 180*. Pull the #1 spark plug and crank it over with your thumb over the spark plug hole. When the compression blows past your thumb, your at TDC on the comression stroke. Check on the balancer to get you around 12-14* BTDC. Put your dizzy in making sure the rotor in pointing to #1 terminal on the cap.
Bill
Bill
billandlori- Posts : 2081
If you need 2 hands to turn the engine over just stick a small piece of paper in #1 and you will know when its on the C stroke. It will BF sometimes when its out just 1 tooth. I always slip the dizzy in when the mark is on 20*
FIRE!.......
FIRE!.......
Mark O'Neal- Posts : 286
Yes we got it it sounds like a monster gota get a new hose for the radiator.Mark O'Neal wrote:NEED FIRING ORDER ASAP
FIRE!.......
J R- Posts : 82
» Firing order swap
» Firing order swap
» Question regarding firing order of 429-460
» Firing Order Swap Cores
» Firing new motor
» Firing order swap
» Firing new motor
