Firing new motor
tconnection
Firing new motor Empty Firing new motor
Post  tconnection December 26th 2012, 6:30 pm
Firing new motor. Solid roller cam. Is it a certain way to brake this cam and motor in?
tconnection
Firing new motor Empty Re: Firing new motor
Post  jbozzelle December 26th 2012, 11:19 pm
Nothing to break in. Just needs to make sure the rings get seated.
Post  tconnection December 27th 2012, 1:34 am
OK thanks but how to get the rings to seat properly?
I didnt use any of the quick seat stuff.
tconnection
Post  cletus66 December 27th 2012, 1:52 am
Use both feet to get up on the converter and power brake it in front of your neighbor's house. Twisted Evil
Post  bbf-falcon December 27th 2012, 5:19 am
tconnection wrote:OK thanks but how to get the rings to seat properly?
If the cylinders and rings are done right,they will seat. Smile
Post  dfree383 December 27th 2012, 10:15 am
Make sure to check the lash after running it for a little while.
Post  tconnection December 31st 2012, 12:10 am
Im wanting to fire this thing off with alcohol. Is there anything special, any tips, tricks or trades to it opposed to using gas? 14:1 580ci. Would a 1150 alky work on it?
tconnection
Post  dfree383 December 31st 2012, 12:34 am
It will work, but its way to small. Gas will definitly make substantialy more power in your situation.
IMO you need to at least break it in on gas to give the rings a fighting change to get seated properly.
Post  cool40 December 31st 2012, 12:38 am
even if your gona run alky you should start it on gas,IMO. gas will start easy,heat up fast,and seat the rings.if you must use alky be sure and have something handy to put out a fire Smile prime it with gas for the first hit....
Post  tconnection December 31st 2012, 2:28 am
Gas it is. I for sure want the rings to seat properly. I was mainly looking toward alky because i felt it would be cheap to crank with as far as stock water pump, cheap radiator and basically no fan. I auctually got a stock water pump bolted on. Now to figure out the best way to stay cool with it. Regular v belt or drive motor?
tconnection
Post  the Coug January 1st 2013, 9:34 am
I always fire my new engines dry and let it run till I can feel the heat on the outside of the front of the head then shut it down let it cool and repeat and hour or so later then put water in it and run it like you stole it....but thats just me....
Post  richter69 January 1st 2013, 3:28 pm
I start and break in (seat the rings) on alky, never an issue.
Last edited by richter69 on January 1st 2013, 6:58 pm; edited 1 time in total (Reason for editing : iPad cant spell for shit.......)
Post  the Coug January 1st 2013, 6:49 pm
richter69 wrote:I start and beak in (seat the rings) on alky, never an issue.
is that a turkey beak or chicken beak? Razz
Post  tconnection January 6th 2013, 1:37 am
Is regular castrol 10w40 ok to use for breaking in this engine? Do i need to add anything to it?
tconnection
