Can this # from a Dyno pull be right
FORDMUD
planotorino
Can this # from a Dyno pull be right Empty Can this # from a Dyno pull be right
Post  planotorino November 15th 2011, 5:07 pm
I don't post here much but I do a tons of reading and research here and 460 Ford sites. Here are my engine spec, sorry if it to long. i think it should be a bit more. Sad The Dyno result is at the bottom. I'm kinda lost on what to do with it. All suggestion and comments are appreciate.
Will be spraying frogger later
1970 Torino with 466, 3850 lbs.
Tranny type: C6 wide ratio with extra clutch plate
Rear end ratio: 3.89 Detroit Locker
Tire diameter: 275X60X15
Intake Manifold type: Single plane Edelbrock Victor Port match head
Carburetor: Holley DP 850 CFM air horn remove
Fuel Pump Size and type: BG400-2
Fuel lines :AN 12 tank to pump: AN-10 feed to Reg: AN8 to Carb: with one AN-8 return
Regulator type: 2 ports BG with return
Idle RPM:1000RPM
Ignition: MSD-6ALN
Current distributor: Lockout MSD 8580 Billet
Current initial timing:30-32
Current max timing
Head type and valve size: Ford Racing FMS-M-6049-SCJA: 2.20 In and 1.76 Ex
Port match to intake
Cam duration at 50: 258 In and 266 Ex
Advertised Duration: In 320 and Ex 328
Cam dial in: 2* retard
Lobe Centerline: 112
Cam lift: 643 with Comp spring CCA-927-16
Cam brand: Crane Cam, Grind # HR-258/372-2S-10
Solid, hydraulic or roller: Hyd Roller Cam, with solid roller lifter and Stud girdle
Exhaust: Hooker 2.5” and 3.5” tail pipe to Dynomax with 3” H-crossover
Compression ratio
Fuel Octane level: 93+
Convertor stall: Up to 4500 RPM
Convertor type:Coan 10” 11 7/16” X 1.375”
High volume oil pump
Canton 8 Qts.oil pan with windage tray and crank scraper
Piston are Ross Racing forged aluminum, gas ported, full floating pin with compression height of 1.753” job # 38605 model # 437. On H-Beam rod
Total Seal Ring, TS1 T8950, gapless second ring
Head gasket use Fel-Pro Z1018, bore 4.5”, compress thickness .041” and compress volume 11.200 CC
https://2img.net/h/i224.photobucket.com/albums/dd124/planotorino/Dynopull.jpg
Can this # from a Dyno pull be right Dynopull
planotorino
Can this # from a Dyno pull be right Empty Re: Can this # from a Dyno pull be right
Post  FORDMUD November 15th 2011, 5:09 pm
That's really hard to see.
FORDMUD
FORDMUD
Post  planotorino November 15th 2011, 5:39 pm
Tried this one full screen.
https://2img.net/h/i224.photobucket.com/albums/dd124/planotorino/Dynopull-1.jpg
or this
Can this # from a Dyno pull be right Th_Dynopull-1
planotorino
Post  quick 52 November 15th 2011, 5:54 pm
something is wrong 100 low
quick 52
Post  4thHorseman November 15th 2011, 7:27 pm
I'd think unless your tune was way the heck off those dyno numbers don't look right at all. Either the operator is incompetent of the dyno setup is jacked.
IMO the carb size is fine for a street machine but you'd make more hp with something bigger at the strip. That combo is stout. I'd bet it should be closer to 500hp.
4thHorseman
4thHorseman
Post  rmcomprandy November 15th 2011, 7:48 pm
Looks a bit rich however, chassis dynos are not a good barometer for actual power with a 4,500 stall speed torque converter; the RWH is most always all over the map. Also, looks like what might be gotten with exhaust manifolds instead of headers.
Use it for a tuning tool and forget about how much the actual numbers say.
Can this # from a Dyno pull be right Empty updated graph
Post  planotorino November 17th 2011, 5:16 pm
Here is an updated graph.
Can this # from a Dyno pull be right Regraphrun
planotorino
Post  IDT-572 November 17th 2011, 7:01 pm
Your torque peak is actually about 305 the 322 was a spike you see when the converter locks on the hit
