Need some advice on a pro street truck build
+14
PROSTREET66
wild pony
Copperhead
jesse
72mav
f250mike
bigblockfox468
18 posters
Page 2 of 2 Previous  1, 2
Need some advice on a pro street truck build - Page 2 Empty re bolt pattern
Post  HorsinAround December 28th 2011, 10:17 am
Changing the rear bolt pattern is easy enough to do on the rear when I put new axles in it. The front
Is another matter. Does someone make a hub with 5 on 4.5 or 4.75 that fits on the ford spindle? Err, just found this thread and it answers my question. https://www.429-460.com/t7979-f150-5x55-to-5x45-wheel-conversion
Now, for the rear 9" is easier in the long run to buy a narrower housing from summit/jegs then to buy and narrow one? Just thinking out loud here since I don't have a 9" now. Also, were there any 9" units with disc brakes?
http://www.frontpagefab.com
Need some advice on a pro street truck build - Page 2 Empty Re: Need some advice on a pro street truck build
Post  f250mike December 28th 2011, 6:24 pm
I'm on a real limited budget, so I will narrow my own stock core housing.
The 80's Lincoln Versailles and maybe early explorers for 9" factory disc brakes.
There are lots of aftermarket 9" disc conversion kits out there. None that I know of for the 5x5.5 bolt pattern though.
mike
f250mike
f250mike
Post  f250mike December 28th 2011, 6:29 pm
I just checked and it looks like the Versailles had rear disc brakes from 1977 thru 80.
f250mike
f250mike
Need some advice on a pro street truck build - Page 2 Empty The project begins
Post  HorsinAround January 1st 2012, 1:06 am
Did a little shopping yesterday. lol
Need some advice on a pro street truck build - Page 2 Horsin_again
Post  Mike R January 1st 2012, 2:15 am
[/quote]
what bumper posted this link earlier http://www.quickperformance.com/index.htm . These guys have a good product at a good price and can fix you up with whatever you need for a rear end.
Post  bigblok2000ranger January 1st 2012, 2:43 am
The late 70 9 inch is a direct bolt in in the 80's trucks I have done a few.
bigblok2000ranger
bigblok2000ranger
Post  schmitty January 1st 2012, 11:29 am
Alan, that link to Quick Performance is all you will need for any part for the rear housing and they have the best bolt on disc brake kit too. Brydon is the man when it comes to the 9". You can't beat the price, quality, service, and knowlege. I you want to put in a 4 link, it really isn't that difficult. I put mine together in about a day with some help from my neighbor. I used a common kit, and a front bracket that bolted to my frame in place of the spring hanger. Cool
Post  HorsinAround January 2nd 2012, 3:27 pm
schmitty wrote:Alan, that link to Quick Performance is all you will need for any part for the rear housing and they have the best bolt on disc brake kit too. Brydon is the man when it comes to the 9". You can't beat the price, quality, service, and knowlege. I you want to put in a 4 link, it really isn't that difficult. I put mine together in about a day with some help from my neighbor. I used a common kit, and a front bracket that bolted to my frame in place of the spring hanger. Cool
What kit did you get? Looking on summit, the ones I see have a sub frame kit, and I'm ignorant as to how those tie into the oem frame. Also, where do I start when spec'ing the coil overs for the rear? Should I replace the oem coils up front for a set of coil overs?
Need some advice on a pro street truck build - Page 2 Empty Pinion angle
Post  HorsinAround January 20th 2012, 3:10 pm
Working on setting up the new axle for the 4 link. What should I set the pinion angle at?
Post  quick 52 January 20th 2012, 3:36 pm
running cal trac they work ok in a bracket car. 60 over 460, victor, 950, 3500 stall, 700r4, 3.89, a429 heads, kb cast 10.2-1, 275x60x15 dr @3870 52 f1 11.43 @116 on motor and street driven all summer
Need some advice on a pro street truck build - Page 2 DSC05578
Need some advice on a pro street truck build - Page 2 DSC05568
quick 52
