valve settings
valve settings Empty valve settings
Post  Larry Williams January 19th 2012, 11:14 am
my cam card calls for .023 and .024 valve lash. With aluminum heads, what would be a proper setting to use? I have tried from .018 to .020 with no noticable difference
Larry Williams
Larry Williams
valve settings Empty Re: valve settings
Post  rmcomprandy January 19th 2012, 12:48 pm
The lash given on cam cards is a RECOMMENDATION. Use whatever runs best with no more than .004" more than the recommendation. That will take a bit of experimentation.
Post  rmcomprandy January 19th 2012, 12:49 pm
Larry Williams wrote:my cam card calls for .023 and .024 valve lash. With aluminum heads, what would be a proper setting to use? I have tried from .018 to .020 with no noticable difference
The differences you mention WILL make a difference however, I don't think you will FEEL just 5 or so horsepower either way.
