valve settings
valve settings
I have read on here about reducing the valve settings when using aluminum heads. I have P51' heads and a comp solid roller that calls for .018/.019 settings. What should I set them for on a cold engine? Its a never fired 545
Larry Williams- Posts : 884
Re: valve settings
If it's a hot lash I would set them cold .015/.016 then check them hot and see where it is
gmsmkr- Posts : 1364
Re: valve settings
Aluminum heads, if the hot lash is .016" and that's where you want it, cold lash is going to be about .026" every head is different, but your going to get somewhere between .008" to .015" growth with the aluminum heads being hot.
kim- Posts : 700
Re: valve settings
Iron block with aluminum heads you subtract from hot lash DO NOT ADD lash for a cold setting
Re: valve settings
Set them cold, to your hot lash setting. Start engine and build heat. Set 1 side, button up. Reheat, set other side. Check cold lash value after your proper hot lash setting.
kim- Posts : 700
Re: valve settings
Set them cold, to your hot lash setting. Start engine and build heat. Set 1 side, button up. Reheat, set other side. Check cold lash value after your proper hot lash setting. That tells you how much your heads grow when hot, and what the minimum lash adjustment you can go to.
And yes, ss pointed out above, my first information was head up ass moment. Too tight hot, can hsve valve off seat cold. Cold lash is that .008 to .010 less than hot.
kim- Posts : 700
Re: valve settings
Larry Williams wrote:I have read on here about reducing the valve settings when using aluminum heads. I have P51' heads and a comp solid roller that calls for .018/.019 settings. What should I set them for on a cold engine? Its a never fired 545
I would set them about .004" tighter when cold with aluminum heads.
Re: valve settings
Randy is my hero.rmcomprandy wrote:Larry Williams wrote:I have read on here about reducing the valve settings when using aluminum heads. I have P51' heads and a comp solid roller that calls for .018/.019 settings. What should I set them for on a cold engine? Its a never fired 545
.004" tighter is usually pretty close.
Keith
Re: valve settings
just the answers I needed thank you all who replied .004 it is
» valve settings
» Going from Ferrea 2.20 valve to 2.25, Is there a better flowing valve for ported STREETS?
» Bump and rebound shock settings
» Recommend baseline carb settings please
» How do you check valve to valve clearance????
