A514 Lash ??
A514 Lash ??
Helpin a buddy, has a A514 solid roller cam n roller lifter set,,,, the cam card calls for .20 .20 hot or .14 .14 cold..... BUT. That is for aluminum heads, whats say you.....Iron heads
samiam- Posts : 240
Re: A514 Lash ??
Hot spec. hot doesnt matter iif the heads are made of stonesamiam wrote:Helpin a buddy, has a A514 solid roller cam n roller lifter set,,,, the cam card calls for .20 .20 hot or .14 .14 cold..... BUT. That is for aluminum heads, whats say you.....Iron heads
DanH- Posts : 1081
Re: A514 Lash ??
try 16/16 first,then go from there.
Re: A514 Lash ??
Try Cold .020-.024 and then check it hot and see where your at.
Re: A514 Lash ??
With iron heads the lash won't change as much. Depending upon the pushrod and rocker arm it won't move more than .002" either way.
