Help! I need a ONE 1/16th compression ring (Got One!)
I need a 1/16th compression ring for Childs/Albert ductile dura moly rings. I have a set that is a few years old and putting my motor together and one compression ring is missing!
Russ Hood
423-718-3279 cell
Russ Hood
423-718-3279 cell
Re: Help! I need a ONE 1/16th compression ring (Got One!)
661-702-1999 ask for Ray Akerly....drop my name if you need to. Akerly & Childs pistons rings.
Good rings,Lem hooked me up a few years back.
» piston ring choice and preferred ring seat/breakin time ?
» Do they make a ductile Iron ring 5/64 X 4.39 bore or whats a good ring?
» Can you raise compression by changing rod length with same compression height?
» how can i tell the compression
» Cam/Compression help on 472
