FOX/standard offset or centerd engine ?
FOX/standard offset or centerd engine  ? Empty FOX/standard offset or centerd engine ?
Post  stanggt February 26th 2012, 12:22 am
is it a big difference wether u place the motor in stadard location or use the plates that center engine? I know I want to line the crank straight up to the pinion and all that. the plate I have now is standard. does it really matter?
stanggt
stanggt
FOX/standard offset or centerd engine  ? Empty Re: FOX/standard offset or centerd engine ?
Post  stanggt February 26th 2012, 10:44 am
cricket!!cricket!!! Sad
stanggt
stanggt
Post  zbob February 26th 2012, 11:19 pm
not a chassis guy at all, but i will mention that drivers side header clearance to the steering shaft was less than 1/4 and header clearance to the frame rail pass side was closer. this was with a d and d kmember, ford racing fox swap mounts on my zeph....something to think on....zbob
zbob
